2960 Stuck in Reboot
aniglio
I have a newly setup 2960 switch that is constantly rebooting. THis is the log, can anyone tell me how to resolve this.
THE FOLLOWING SEQUENCE WAS REPEATED AUTOMATICALLY NON-STOP
CPU rev: B
Image passed digital signature verification
Board rev: 18
Testing DataBus...
Testing AddressBus...
Testing Memory from 0x00000000 to 0x1fffffff.../
Using driver version 4 for media type 1
Xmodem file system is available.
Base ethernet MAC Address: 2c:0b:e9:f0:d7:00
The password-recovery mechanism is enabled.
USB EHCI 1.00
USB EHCI 1.00
USB Console INIT
Initializing Flash...
mifs[5]: 12 files, 1 directories
mifs[5]: Total bytes     :    1806336
mifs[5]: Bytes used      :     833536
mifs[5]: Bytes available :     972800
mifs[5]: mifs fsck took 0 seconds.
mifs[6]: 1 files, 1 directories
mifs[6]: Total bytes     :    3870720
mifs[6]: Bytes used      :    1004032
mifs[6]: Bytes available :    2866688
mifs[6]: mifs fsck took 1 seconds.
mifs[7]: 5 files, 1 directories
mifs[7]: Total bytes     :     258048
mifs[7]: Bytes used      :       8192
mifs[7]: Bytes available :     249856
mifs[7]: mifs fsck took 0 seconds.
mifs[8]: 5 files, 1 directories
mifs[8]: Total bytes     :     258048
mifs[8]: Bytes used      :       8192
mifs[8]: Bytes available :     249856
mifs[8]: mifs fsck took 0 seconds.
mifs[9]: 544 files, 131 directories
mifs[9]: Total bytes     :  122185728
mifs[9]: Bytes used      :   74171904
mifs[9]: Bytes available :   48013824
mifs[9]: mifs fsck took 50 seconds.
...done Initializing Flash.
Loading "flash:/c2960x-universalk9-mz.152-6.E1/c2960x-universalk9-mz.152-6.E1.bin"...Verifying image flash:/c2960x-universalk9-mz.152-6.E1/c2960x-universalk9-mz.152-6.E1.bin.......................................................................................................................................................................................................................................................................................................................................................................................................................Image passed digital signature verification
POWERED OFF AND ON THE DEVICE
File "flash:/c2960x-universalk9-mz.152-6.E1/c2960x-universalk9-mz.152-6.E1.bin" uncompressed and installed, entry point: 0x3000
executing...
              Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
           cisco Systems, Inc.
           170 West Tasman Drive
           San Jose, California 95134-1706
Cisco IOS Software, C2960X Software (C2960X-UNIVERSALK9-M), Version 15.2(6)E1, RELEASE SOFTWARE (fc4)
Copyright (c) 1986-2018 by Cisco Systems, Inc.
Compiled Tue 06-Mar-18 06:58 by prod_rel_team
Initializing flashfs...
mifs[7]: 12 files, 1 directories
mifs[7]: Total bytes     : 1806336
mifs[7]: Bytes used      : 833536
mifs[7]: Bytes available : 972800
mifs[7]: Initialization complete.
mifs[8]: 1 files, 1 directories
mifs[8]: Total bytes     : 3870720
mifs[8]: Bytes used      : 1004032
mifs[8]: Bytes available : 2866688
mifs[8]: Initialization complete.
mifs[9]: 5 files, 1 directories
mifs[9]: Total bytes     : 258048
mifs[9]: Bytes used      : 8192
mifs[9]: Bytes available : 249856
mifs[9]: mifs fsck took 0 seconds.
mifs[9]: Initialization complete.
mifs[10]: 5 files, 1 directories
mifs[10]: Total bytes     : 258048
mifs[10]: Bytes used      : 8192
mifs[10]: Bytes available : 249856
mifs[10]: mifs fsck took 0 seconds.
mifs[10]: Initialization complete.
mifs[11]: 544 files, 131 directories
mifs[11]: Total bytes     : 122185728
mifs[11]: Bytes used      : 74171904
mifs[11]: Bytes available : 48013824
mifs[11]: mifs fsck took 1 seconds.
mifs[11]: Initialization complete.
...done Initializing flashfs.
Checking for Bootloader upgrade..
Boot Loader upgrade not required (Stage 2)
FIPS: Flash Key Check : Begin
FIPS: Flash Key Check : End, Not Found, FIPS Mode Not Enabled
extracting front_end/front_end_ucode_info (43 bytes)
POST: MA BIST : Begin***ERR: S88G MDIO Read - Address is not decoded.
POST: MA BIST : End, Status Failed
POST: BIST failed
POST: ACT2 Authentication : Begin
POST: ACT2 Authentication : End, Status Passed
driver class subsystem initialization failed
 09:08:14 UTC Fri Sep 7 2018: Unexpected exception to CPUvector 300, PC = 3940D20
-Traceback= 0x3940D20z 0x38329D8z 0x382F0BCz 0x382BBD4z 0x2D09018z 0x2D091F4z 0x2D0936Cz 0x82033Cz 0x820564z 0x3B1DE5Cz 0x3B19B4Cz
Writing crashinfo to flash:/crashinfo_ext/crashinfo_ext_216
=== Flushing messages (09:08:24 UTC Fri Sep 7 2018) ===
Buffered messages:
Queued messages:
Sep  7 09:08:24.945: %SYS-3-LOGGER_FLUSHING: System pausing to ensure console debugging output.
*Mar  1 00:00:57.790: Read env variable - LICENSE_BOOT_LEVEL =
*Jan  2 00:00:00.083: %IOS_LICENSE_IMAGE_APPLICATION-6-LICENSE_LEVEL: Module name = c2960x_lanbase Next reboot level = lanbase and License = lanbase
Sep  7 09:08:06.113:  in Switch 0. Cannot read pid from Flexstack module
Sep  7 09:08:14.456: %PLATFORM_IPC-3-COMMON: Init failed before IPC init
-Traceback= 80E6DCz 348BF08z 35DF748z 2D09018z 2D091F4z 2D0936Cz 8202F4z 820564z 3B1DE5Cz 3B19B4Cz
Sep  7 09:08:14.586: platform assert failure: 0: ../src-hulc/src-strider/strider_hqatm.c: 6321: strider_hqatm_set_snap_bridging
Sep  7 09:08:14.586: -Traceback= 80FB50z 35DCD0Cz 38479D8z 3487B70z 2D09018z 2D091F4z 2D0936Cz 82033Cz 820564z 3B1DE5Cz 3B19B4Cz
Data Access Exception (0x0300)!
SRR0 = 0x03940D20  SRR1 = 0x00029200  SRR2 = 0x034D7B1C  SRR3 = 0x00029200
ESR = 0x00800000  DEAR = 0x00000B00  TSR = 0x84000000  DBSR = 0x00000000
CPU Register Context:
Vector = 0x00000300  PC = 0x03940D20  MSR = 0x00029200  CR = 0x48000028
LR = 0x038329D8  CTR = 0x0073E550  XER = 0x6000007F
R0 = 0x780A43A6  R1 = 0x08B580E0  R2 = 0x00000000  R3 = 0x00000B00
R4 = 0x00000000  R5 = 0x00042805  R6 = 0xC0000B00  R7 = 0x0000000A
R8 = 0x7C7043A6  R9 = 0x00000010  R10 = 0x010A0170  R11 = 0x000A0000
R12 = 0x0000000B  R13 = 0x1F183944  R14 = 0x00820508  R15 = 0x00000000
R16 = 0x00000000  R17 = 0x00000000  R18 = 0x00000000  R19 = 0x00000000
R20 = 0x00000000  R21 = 0x00000000  R22 = 0x00000000  R23 = 0x00000000
R24 = 0x00000000  R25 = 0x00000000  R26 = 0x00000000  R27 = 0x08100000
R28 = 0x00000000  R29 = 0x08B58110  R30 = 0x00000000  R31 = 0x08104974
Stack trace:
PC = 0x03940D20, SP = 0x08B580E0
Frame 00: SP = 0x08B580E8    PC = 0x0073E540
Frame 01: SP = 0x08B58100    PC = 0x0382F0BC
Frame 02: SP = 0x08B58148    PC = 0x0382BBD4
Frame 03: SP = 0x08B58158    PC = 0x02D09018
Frame 04: SP = 0x08B58178    PC = 0x02D091F4
Frame 05: SP = 0x08B58190    PC = 0x02D0936C
Frame 06: SP = 0x08B581C0    PC = 0x0082033C
Frame 07: SP = 0x08B582C0    PC = 0x00820564
Frame 08: SP = 0x08B582C8    PC = 0x03B1DE5C
Frame 09: SP = 0x00000000    PC = 0x03B19B4C
Switch uptime is 1 minute, 26 seconds
cisco WS-C2960X-48LPS-L (APM86XXX) processor (revision A0) with 524288K bytes of memory.
Processor board ID FCW2125B64X
CPU rev: B
Board rev: 18
Testing DataBus...
CPU rev: B
Board rev: 18
Testing DataBus...
Testing Memory from 0x00000000 to 0x1fffffff...|
Hello
Has is every worked?
Have your recently upgraded the software or performed any maintenance on it?
Kind Regards
Paul
Yes it did work when first powered up.
I did not do the actual work on the switch so I would have to confirm what changes were made. My biggest concern is trying to identify if this is a hardware or configuration/software fault.
Leo Laohoo
POST: BIST failed
There are two issues here.
First one, I suspect this is a bug with the choice of IOS version.  Use a different one.
1.  Power down the switch (pull the cable).
2.  Apply power to the switch and force the switch to boot into ROMmon.
3.  Use IOS version 15.2(4)E6.  Download the BIN file (from the Cisco website) to a USB flash.
4.  Force the switch to boot this IOS using the command "boot usbflash0:IOS_filename.bin".
When the switch is stable, please don't forget to delete the crashinfo and crashinfo_ext sub-directories before the flash gets full.  The command is "del /f /r flash:crashinfo*".
