2960 switch configuration got removed after power flap!
dnsroot13
Hi Guys,
have a weird issue.there are 3 switches from where the entire configuration & vlan.dat as well got removed after a power outage.
if you reboot the switch manually  its not having  any issue and configuration still exists in the switch.could not found any bug as well on IOS although its very old.
appreciate if anybody can suggest the cause of this,
below are the details of the switch .
------------------ show version ------------------
Cisco IOS Software, C2960 Software (C2960-LANLITEK9-M), Version 12.2(50)SE5, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Tue 28-Sep-10 13:44 by prod_rel_team
Image text-base: 0x00003000, data-base: 0x01200000
ROM: Bootstrap program is C2960 boot loader
BOOTLDR: C2960 Boot Loader (C2960-HBOOT-M) Version 12.2(44r)SE4, RELEASE SOFTWARE (fc1)
 uptime is 2 days, 9 hours, 9 minutes
System image file is "flash:c2960-lanlitek9-mz.122-50.SE5/c2960-lanlitek9-mz.122-50.SE5.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco WS-C2960-24TC-S (PowerPC405) processor (revision N0) with 65536K bytes of memory.
Processor board ID
Last reset from power-on
1 Virtual Ethernet interface
24 FastEthernet interfaces
2 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
64K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address       : A4:18:75:5F:40:00
Motherboard assembly number     :
Power supply part number        :
Motherboard serial number       :
Power supply serial number      : DCA16108061
Model revision number           : N0
Motherboard revision number     : A0
Model number                    : WS-C2960-24TC-S
System serial number            :
Top Assembly Part Number        : 800-29857-05
Top Assembly Revision Number    : C0
Version ID                      : V07
CLEI Code Number                : COMCV00ARB
Hardware Board Revision Number  : 0x01
Switch Ports Model              SW Version            SW Image
*    1 26    WS-C2960-24TC-S    12.2(50)SE5           C2960-LANLITEK9-M
Configuration register is 0xF
0 Replies 0
