2960G Switch not powering
rramraj123
Hi, Suddenly my 2960 D series switch went offline and i founf the switch was not powering. I can't figure out the issue. Please help.
rramraj123
Its my bad .. the switch was 2960 G series.
Hi Rajesh,
Kindly check the below things:
1- Is power socket and cable is good.
2- Try to use different power cable and socket and check if the device is getting power on?
3-  If power is fine then the switch seems to be gone bad/faulty.
Raise an RMA to get the replacement for the same.
Inayath
*Plz rate the usefull posts.
Samir Aliyev
Did you give the switch to electronics specialist  for power supply checking?
