09-08-2011 05:17 AM - edited 03-07-2019 02:06 AM
Hello all, im after some advice.
I have setup 2 2960s with flexstack. I have setup a channel group (LACP) on G1/0/1 + G2/0/1 (cross stack) which connect to a storage box.
I'm a little stuck when it comes to the load balacing and fail over;
Do i use source IP or destination IP? or sourse MAC or destination MAC?
And would the command LACP direct-loadswap be the key to the failover?
Thanks in advance
09-08-2011 05:32 AM
Src Mac - Dst Mac Load balancing:
++ For the 2950/2955/3550 series switch, EtherChannel balances the traffic load across the links in a channel by randomly associating a newly learned MAC address with one of the links in the channel.
EtherChannel load balancing can use either source-MAC or destination-MAC address forwarding.
With source-MAC address forwarding, when packets are forwarded to an EtherChannel, the packets are distributed across the ports in the channel based on the source-MAC address of the incoming packet.
Therefore, to provide load balancing, packets from different hosts use different ports in the channel, but packets from the same host use the same port in the channel.
With destination-MAC address forwarding, when packets are forwarded to an EtherChannel, the packets are distributed across the ports in the channel based on the destination host MAC address of the incoming packet.
Therefore, packets to the same destination are forwarded over the same port, and packets to a different destination are sent on a different port in the channel.
SRC IP- DST IP Load balance:
when source-MAC address forwarding is used, load distribution based on the source and destination IP address is also enabled for routed IP traffic.
All routed IP traffic chooses a port based on the source and destination IP address. Packets between two IP hosts always use the same port in the channel, and traffic between any other pair of hosts can use a different port in the channel.
So basically the load-balance mechanism can be chosen based on the type of traffic passing through the etherchannel.
++ If the traffic is only layer 2 traffic, then we can prefer source mac-destination mac load balancing
++ If the traffic is a routed traffic, then use source-ip destination ip load balancing
The command "LACP direct-loadswap can be used for only a single bundled port failure.
If a second failure occurs before the first failure recovers, the loadshare bits for member links are recomputed.
++ So this command ideally comes into place if a link in the port-channel fails.
Hope this helps.
Cheers
Somu
Rate helpful posts
09-08-2011 09:26 AM
Ok i tried src-dest-mac ad ip and when i simulate a switch failure my running ping just times out until the switch i pulled the power out of comes back up. The storage box itself has 2 NICS which i've set up as lacp so they are one... Is it correct to set this and at the switch end also?
On another note the lacp direct-loadswap command doesn't appear to be available.
