Showing results forĀ
Search instead forĀ
Did you mean:Ā
2960S - FlexStack module Auth failed
slizarraga
Level 2
Level 2
I have been trying to make a stack with two 2960S. They have the same IOS but they behave as they were not connected.
One is in production and I am attaching a brand new one to it; in the one that is in production I get these 2 messages:
FlexStack Module SmartChip Authentication Failed
Jun  1 16:54:27.984 GMT-5: %ILET-1-DEVICE_AUTHENTICATION_FAIL: The FlexStack Mod
ule inserted in this switch may not have been manufactured by Cisco or with Cisc
o's authorization. If your use of this product is the cause of a support issue,
Cisco may deny operation of the product, support under your warranty or under a
Cisco technical support program such as Smartnet.  Please contact Cisco's Techni
cal Assistance Center for more information.
I tried switching the modules and the outcome is the same, so I think the modules are ok.
What to you recommend, is there a way to bypass this authentication?
Thanks for your help,
Sergio
6 Replies 6
Leo Laohoo
Hmmm ...
I've seen this before and I've fixed this (several times) but you do you really want to know how I did this?
Power down the switch and re-insert the stacking module is one method.  Make very sure the s_crews are secure (and not just finger-tight).  If the error message returned, I would power down the switch, remove the stacking module and WHACK the flat side of the stacking module on a surface (NOT the intention of breaking the module) and re-inserting the module back.
I pray you don't have to result in the 2nd method.
b.gamble
Level 4
Level 4
A firmware update did the trick for me.
Re-seating the module didn't work and I didn't try whacking it off of my desk.
What version were you running and what version did you upgrade to?  I am having the same issue while running 122-55.SE2
Thanks.
I upgraded to 15.0(2). I'm not sure what version I was on before.
Even after the IOS upgrade I still had one faulty module that I had to return. I probably had four modules total give me grief and the IOS upgrade fixed all but one of them.
The version I was using is
15.0(1)SE2.
slizarraga
Level 2
Level 2
Fortunately, I had another switch so I installed those and I am migrating the connections to this new pair of switches. I think a reload would have help, but this switch is in production.
Thanks!
