2960X-24P unable to write in flash
naeemu518
i have a cisco catalyst switch series of 2950X-24P, we are facing some issue on switch is that when we are modified configuration like we create vlan and that vlan assigned on port of the switch. when we are saving the configuration some errors are generate like no space available information.
troubleshooting of the switch: reboot the switch same issue observed. perhaps the flash memory is faulty?
6 Replies 6
balaji.bandi
check the flash with below command :
dir flash:
dir nvram:
show ver
may be check is the service compress-config applied on the global.
also try new IOS code by famating and loading may fix issue (this could be bug based on the code you using ?)
BB
Leo Laohoo
What is the exact error message?
naeemu518
the exact error like this.
Switch#sh fla Directory of flash:/ %Error opening flash:/ (Invalid argument) No space information available
the config register value is 0xf
@naeemu518 wrote:
Switch#sh fla
%Error opening flash:/ (Invalid argument)​
The syntax is incorrect.  Try "dir" only.
naeemu518
@Leo Laohoo also try this command but still same issue observed.
I want to see the output.
