2960x latency for 1G uplink port
illusion_rox
Hi Experts,
Can someone help to confirm latency for 1G uplink ports in 2960x series switches? cant find them in datasheets
Mark Malone
There would be no stat for that latency is a measurement test source to destination it's not based on a port itself ,you can for ratio stats see how many ports are bound to each ASIC in the platform itself , the ports are line rate on a 2960 switch in terms of forwarding
Joseph W. Doherty
For a switch like a 2960 series, that might not even be documented by Cisco.  However, sometimes 3rd party performance tests have it.  See if first table on page 11 of http://miercom.com/pdf/reports/20130917.pdf helps.
BTW, generally switch latency is often only documented when dealing with low-latency cut-through switches, i.e. those designed to minimize end-to-end latency.  "Ordinary" network designs don't generally "worry" about 10 microseconds or so of additional latency per switch.
