2960x MPPS
i need to know how many MPPS for the ws-c2960x-48TS-L ? because it does not mentioned in the datasheet .
Its not how its calculated its the actual hardware and what Cisco say it can push per second
Here's the doc shows what each 2960 type is capable of , X series are slightly faster t6han standard while xr can hit 130 mpps
http://www.cisco.com/c/en/us/products/collateral/switches/catalyst-2960-x-series-switches/data_sheet_c78-728232.html
Mark Malone
That's it
Cisco Catalyst 2960X-48TS-L
107.1 Mpps
Thanks mark alot , but can you tell me how to calculate it ?
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages wha2tsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
As Mark has noted, you can not calculate what the hardware will do, either the vendor needs to tell you or you can test the device's performance.
However, you can calculate what PPS rate is needed for "wire-speed" Ethernet.  For example, non-tagged Ethernet, for minimum size packets, needs about 1.488 Mpps per Gbps.
