3064PQ Port mirror performance
blackmetal
We have an N3K-C3064PQ-10GX with ~12g bps and 5m pps with 2x 10G LACP from our ip transit, we want to connect a server with 2x 10g to this 3064pq for traffic analyzing and mirror uplink port-channel to this server,
so i want to know port mirror this amount of data from one port-channel to another port-channel impact on CPU or cause any CPU issues?
Thank you.
5 Replies 5
blackmetal
any update on this topic?
Christopher Hart
Hello!
On Nexus switches, replication of packets from SPAN monitor sessions are performed in hardware. Therefore, there will be no impact on the control plane CPU of the switch when a SPAN monitor session is active.
You can use the Ethanalyzer control plane packet capture tool to confirm that no data plane traffic replicated by a SPAN monitor session can be observed by the control plane of the switch.
I hope this helps - thank you!
-Christopher
blackmetal
@Christopher Hart
as i read https://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus3000/sw/system_mgmt/503_u2_2/Cisco_Nexus_3000_system_mgmt_config_gd_503_U2_2_chapter13.pdf it seems there are some limitation for monitor session and it seems it can not monitor more than 6gbps is it correct?
i have around 9gbps bps and i want to mirror it to another port, can this traffic mirror completly ?
also is it posible mirror a port-channel to another one ?
i am using n3k-c3064pq-10gx
Hello!
It sounds like you are referring to the following limitation:
"If the SPAN source interface sends more than 6-Gbps traffic or if traffic bursts too much, the device drops traffic on the source interface. You can use the switchport monitor rate-limit 1G command on the SPAN destination to reduce the dropping of actual traffic on the source interface; however, SPAN traffic is restricted to 1 Gbps."
Based on that limitation, you will not be able to replicate all 9Gbps of your data plane traffic without dropping some data plane traffic.
Port-channels are not supported as SPAN destination ports - see the "Characteristics of Destination Ports" section of the Cisco Nexus 3000 Series NX-OS System Management Configuration Guide.
Thank you!
-Christopher
blackmetal
i am really curious why does this limitation available? this switch can handle 1tbps bps but for span we can have 6gbps only?
