3120x stack - can use LACP ?
steve switzer
Can i use LACP in a stack across different 3120x switches ?
When i last tried it i recieved an error message.
The intention is to bind 4 different ports on 2 different switches
in the same stack - but when going from on to active
on the 3120 I get an error.
Steve
mcusine
Hi Steve,
I was looking in cisco doc but in the datasheet say etherchannel it's supported but don't say anything for LACP.
http://www.cisco.com/en/US/prod/collateral/switches/ps6746/ps8742/ps8749/data_sheet_c78-439133.html
Mauricio
cashqoo
from the documents, it seems that it supports LACP over switch stack.
http://www.cisco.com/en/US/docs/switches/blades/3120/software/release/12.2_55_se/configuration/guide/swethchl.html#wp1275680
>>By using LACP, the switch or switch stack learns  the identity of partners capable of supporting LACP and the capabilities  of each port.
