3524 switch
jose.jimenez
I have a 3524-pwr-xl with a red light besides "system" on the front bezel/panel. How can I find out what that means and what is causing it to light up. Thanks!
Is that the RPS LED? What does your syslog message say ?
Yes, it's above the RPS. How can I check the syslog?
Connect the console port to your laptop and under config mode, do "logging console" and see what messages you get on the console.
Can you post those messages?
