3548 switch and DHCP not working!
rhilliker
Hello all,
I have a switch that is setup with basic config and the issue that i am having is that when I connect computers to the switch and have the computer setup for dynamic, it does not see the network. But when I put a static IP on the computer is automatically sees the network. I am at a lose for what the issue could be. Thanks for any and all help, Richie.
davy.timmermans
Level 4
Level 4
1)do you want to setup the switch as DHCP server or do you have a DHCP server running in the network?
If you have DHCP server running in the network, is it on another vlan than the users? --> yes
configure ip helper-address under SVI or subinterface
ip helper-adress IP_DHCP
