3550 switch not booting
sagar.saxena
R16 = 0x00000000  R17 = 0x00000000  R18 = 0x00B0E56C  R19 = 0x00A9BED0
R20 = 0x00000000  R21 = 0x00000000  R22 = 0x00A9BFD0  R23 = 0x00000000
R24 = 0x000007D0  R25 = 0x00006000  R26 = 0x00000000  R27 = 0x00000000
R28 = 0x00970000  R29 = 0x000004C8  R30 = 0x00000400  R31 = 0x00000000
Stack trace:
PC = 0x002AD774, SP = 0x00A9BE40
Frame 00: SP = 0x00A9BE78    PC = 0x002AD724
Frame 01: SP = 0x00A9BEC8    PC = 0x002C2014
Frame 02: SP = 0x00A9BFF8    PC = 0x0034C94C
Frame 03: SP = 0x00A9C010    PC = 0x002E8B44
Frame 04: SP = 0x00000000    PC = 0x001C6440
üüBase ethernet MAC Address: 00:0e:38:de:bd:80
Xmodem file system is available.
The password-recovery mechanism is enabled.
Initializing Flash...
flashfs[0]: sector 102, block 60 checksum (0xd804 != 0xe2f0)
flashfs[0]: sector 103, block 60 checksum (0x3f46 != 0xe2f0)
flashfs[0]: 24 files, 4 directories
flashfs[0]: 0 orphaned files, 0 orphaned directories
flashfs[0]: Total bytes: 15998976
flashfs[0]: Bytes used: 5265408
flashfs[0]: Bytes available: 10733568
flashfs[0]: flashfs fsck took 19 seconds.
...done Initializing Flash.
Boot Sector Filesystem (bs:) installed, fsid: 3
Loading "flash:c3550-i9q3l2-mz.121-13.EA1a/c3550-i9q3l2-mz.121-13.EA1a.bin"...##
File "flash:c3550-i9q3l2-mz.121-13.EA1a/c3550-i9q3l2-mz.121-13.EA1a.bin" uncompr
essed and installed, entry point: 0x3000
executing...
              Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
           cisco Systems, Inc.
           170 West Tasman Drive
           San Jose, California 95134-1706
IOS (tm) C3550 Software (C3550-I9Q3L2-M), Version 12.1(13)EA1a, RELEASE SOFTWARE
(fc1)
Copyright (c) 1986-2003 by cisco Systems, Inc.
Compiled Tue 25-Mar-03 23:21 by yenanh
Image text-base: 0x00003000, data-base: 0x00654C9C
Initializing flashfs...
flashfs[1]: 24 files, 4 directories
flashfs[1]: 0 orphaned files, 0 orphaned directories
flashfs[1]: Total bytes: 15998976
flashfs[1]: Bytes used: 5266432
flashfs[1]: Bytes available: 10732544
flashfs[1]: flashfs fsck took 8 seconds.
flashfs[1]: Initialization complete.
...done Initializing flashfs.
POST: CPU Buffer Tests : Begin
POST: CPU Buffer Tests : End, Status Passed
POST: CPU Interface Tests : Begin
Timeout while verifying the CPU Interface channel 0 on switch core 0
POST: CPU Interface Tests : End, Status Failed
CPU Interface Queue Initialization Failedcisco WS-C3550-48 (PowerPC) processor (
revision J0) with 65526K/8192K bytes of memory.
Processor board ID CAT0745Z0FE
Last reset from warm-reset
Running Layer2/3 Switching Image
384K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 00:0E:38:DE:BD:80
Motherboard assembly number: 73-5701-08
Power supply part number: 34-0967-01
Motherboard serial number: CAT07440592
Power supply serial number: DTH074223SU
Model revision number: J0
Motherboard revision number: A0
Model number: WS-C3550-48-SMI
System serial number: CAT0745Z0FE
!!! WARNING: The switch is not usable !!!
Reason:
Unexpected exception to CPU vector 300, PC = 2AD774
-Traceback= 2AD774 2C2014 34C94C 2E8B44 1C6440
=== Flushing messages (00:00:11 UTC Mon Mar 1 1993) ===
Buffered messages:
Queued messages:
00:00:11: %SYS-3-LOGGER_FLUSHING: System pausing to ensure console debugging out
put.
00:00:10: %SYS-2-NULLCHUNK: Memory requested from Null Chunk
-Process= "Init", ipl= 0, pid= 3
-Traceback= 1A1310 2BB698 2CE4B0 2AB258 1BD3E8 1BD498 104504 104708 1C6440
00:00:10: %SPANTREE-5-EXTENDED_SYSID: Extended SysId enabled for type vlan
00:00:11: %SCHED-2-WATCH: Attempt to set uninitialized watched boolean (address
0).
-Process= "VLAN Manager", ipl= 0, pid= 25
-Traceback= 1B67AC 2C4C08 35258C 34A2D4 3A6AEC 3AE308 3A9A84 3ACED8 3A99A0 3A4CD
0 1C6440
(fc1)
Data Access Exception (0x0300)!
CPU Register Context:
Vector = 0x00000300  PC = 0x002AD774  MSR = 0x00009030  CR = 0x28000000
LR = 0x002AD758  CTR = 0x001B7884  XER = 0x00000000
R0 = 0x00000000  R1 = 0x00A9B8F8  R2 = 0x00000000  R3 = 0x00A9B900
R4 = 0x00000400  R5 = 0xFEC0FEC0  R6 = 0xFEE00000  R7 = 0x00001030
R8 = 0x00009030  R9 = 0x908000A4  R10 = 0x000000A4  R11 = 0x00000000
R12 = 0x000003C0  R13 = 0x8B77B283  R14 = 0x00000000  R15 = 0x00000000
R16 = 0x00000000  R17 = 0x00000000  R18 = 0x00B0B508  R19 = 0x00A9B988
R20 = 0x00000000  R21 = 0x00000000  R22 = 0x00A9BA88  R23 = 0x00000000
Stack trace:
PC = 0x002AD774, SP = 0x00A9B8F8
Frame 00: SP = 0x00A9B930    PC = 0x002AD724
Frame 01: SP = 0x00A9B980    PC = 0x002C2014
Frame 02: SP = 0x00A9BAB0    PC = 0x0034C94C
Frame 03: SP = 0x00A9BAC8    PC = 0x002E8B44
flashfs[0]: Bytes used: 5266432
flashfs[0]: Bytes available: 10732544
flashfs[0]: flashfs fsck took 21 seconds.
executing...
           cisco Systems, Inc.
(fc1)
flashfs[1]: flashfs fsck took 14 seconds.
Reason:
=== Flushing messages (00:00:17 UTC Mon Mar 1 1993) ===
Buffered messages:
Queued messages:
00:00:17: %SYS-3-LOGGER_FLUSHING: System pausing to ensure console debugging out
put.
00:00:16: %SYS-2-NULLCHUNK: Memory requested from Null Chunk
00:00:16: %SPANTREE-5-EXTENDED_SYSID: Extended SysId enabled for type vlan
(fc1)
LR = 0x002AD758  CTR = 0x001B7938  XER = 0x00000000
R0 = 0x00000000  R1 = 0x00A9BE80  R2 = 0x00000000  R3 = 0x00A9BE88
R8 = 0x00009030  R9 = 0x908000A4  R10 = 0x00000004  R11 = 0x00000000
R12 = 0x000003C4  R13 = 0x8B77B283  R14 = 0x00000000  R15 = 0x00000000
R16 = 0x00000000  R17 = 0x00000000  R18 = 0x00B0E5B0  R19 = 0x00A9BF10
R20 = 0x00000000  R21 = 0x00000000  R22 = 0x00A9C010  R23 = 0x00000000
Stack trace:
PC = 0x002AD774, SP = 0x00A9BE80
Frame 00: SP = 0x00A9BEB8    PC = 0x002AD724
Frame 01: SP = 0x00A9BF08    PC = 0x002C2014
Frame 02: SP = 0x00A9C038    PC = 0x0034C94C
Frame 03: SP = 0x00A9C050    PC = 0x002E8B44
àBase ethernet MAC Address: 00:0e:38:de:bd:80
flashfs[0]: sector 105, block 60 checksum (0xb56a != 0xe2f0)
flashfs[0]: sector 106, block 60 checksum (0x86d9 != 0xe2f0)
flashfs[0]: 25 files, 4 directories
flashfs[0]: Bytes used: 5265920
flashfs[0]: Bytes available: 10733056
executing...
           cisco Systems, Inc.
(fc1)
flashfs[1]: 25 files, 4 directories
flashfs[1]: Bytes used: 5266944
flashfs[1]: Bytes available: 10732032
Reason:
Buffered messages:
Queued messages:
put.
0).
0 1C6440
(fc1)
R0 = 0x00000000  R1 = 0x00A9B940  R2 = 0x00000000  R3 = 0x00A9B948
R8 = 0x00009030  R9 = 0x908000A4  R10 = 0x000000A8  R11 = 0x00000000
R12 = 0x000003C0  R13 = 0xCBF7B283  R14 = 0x00000000  R15 = 0x00000000
R16 = 0x00000000  R17 = 0x00000000  R18 = 0x00B0B54C  R19 = 0x00A9B9D0
R20 = 0x00000000  R21 = 0x00000000  R22 = 0x00A9BAD0  R23 = 0x00000000
Stack trace:
PC = 0x002AD774, SP = 0x00A9B940
Frame 00: SP = 0x00A9B978    PC = 0x002AD724
Frame 01: SP = 0x00A9B9C8    PC = 0x002C2014
Frame 02: SP = 0x00A9BAF8    PC = 0x0034C94C
Frame 03: SP = 0x00A9BB10    PC = 0x002E8B44
flashfs[0]: Bytes used: 5266944
flashfs[0]: Bytes available: 10732032
executing...
           cisco Systems, Inc.
(fc1)
Reason:
Buffered messages:
Queued messages:
put.
(fc1)
R0 = 0x00000000  R1 = 0x00A9BEC8  R2 = 0x00000000  R3 = 0x00A9BED0
R8 = 0x00009030  R9 = 0x908000A4  R10 = 0x000000B8  R11 = 0x00000000
R12 = 0x000003C4  R13 = 0xCBF7B283  R14 = 0x00000000  R15 = 0x00000000
R16 = 0x00000000  R17 = 0x00000000  R18 = 0x00B0E5F4  R19 = 0x00A9BF58
R20 = 0x00000000  R21 = 0x00000000  R22 = 0x00A9C058  R23 = 0x00000000
Stack trace:
PC = 0x002AD774, SP = 0x00A9BEC8
Frame 00: SP = 0x00A9BF00    PC = 0x002AD724
Frame 01: SP = 0x00A9BF50    PC = 0x002C2014
Frame 02: SP = 0x00A9C080    PC = 0x0034C94C
Frame 03: SP = 0x00A9C098    PC = 0x002E8B44
krahmani323
Level 3
Level 3
Hello Sagar,
From the output we can see :
POST failure usually means there is physical damage. You need to replace your switch (do a RMA).
Thanks.
Karim
