3560 and 3560E
dangal.43
what is main difference between 3560 and 3560E switches?
mohammedmahmoud
Level 11
Level 11
Q. What are the notable differences/features between the Cisco Catalyst 3560-E and the Cisco Catalyst 3560?
A. The differences are as follows:
? Cisco Catalyst 3560-E provides a true line-rate (nonblocking) Gigabit Ethernet to the desktop solution with two line-rate 10 Gigabit Ethernet uplinks.
? The Cisco Catalyst 3560-E has a backplane switching ASIC, which also makes forwarding decisions, to help the switch perform wire-rate local switching.
? The Cisco Catalyst 3560-E supports dynamic a pluggable module that converts a 10 Gigabit Ethernet slot into a slot that can fit 2 Gigabit Ethernet ports. This allows for easy migration for customers moving from Gigabit Ethernet uplinks to 10 Gigabit Ethernet uplinks.
? The Cisco Catalyst 3560-E supports hot-swappable power supplies.
? The Cisco Catalyst 3560-E supports jumbo frame routing and increases the frame size to 9216 bytes.
? The Cisco Catalyst 3560-E supports uncompressed IPv6 address tables. This allows the software to program the full IPv6 address in the hardware. In addition, equal cost routing for IPv6 uses the uncompressed IPv6 address.
? The Cisco Catalyst 3560-E supports destination stripping of unicast packets.
http://www.cisco.com/en/US/products/ps7078/products_qanda_item0900aecd805bacc7.shtml
HTH, please rate if it does help,
Mohammed Mahmoud.
