3560X port numbering/interfaces
           On a 3560X, 24-port, the first 24 ports are numbered 0/1 - 24, correct?  For the optional Network/Service Module, are the 4 ports numbered 0/25 - 0/28?  Thank you
Jose Solano
Level 4
Level 4
See this,
   Network Module Interfaces
The uplink ports on the 10 Gigabit service module and on the 10 Gigabit Ethernet network module are labeled Te1/Gi2 and Te2/Gi4. These ports can operate at either 1 Gigabit per second or 10 Gigabits per second. They are identified in software as gigabitethernet x/1/2 and x/1/4 andtengigabitethernet x/1/1 and x/1/2, with x being the switch number on Catalyst 3750-X stacks. The Catalyst 3560-X switch port numbers are the same, with no switch number.
http://www.cisco.com/en/US/docs/switches/lan/catalyst3750x_3560x/software/release/15.0_1_se/configuration/guide/swint.html#wp1878796
Hope this helps.
Jose Solano
Level 4
Level 4
See this,
Hope this helps.
Thanks Leo.  I re-read and finally got it.  I appreciate your assistance.
Hi Leo,
No TenGigabitEthernet SFPs; wish we did.  For the 3560X with 4 1Gig SFPs, the port numbering would be 1/1, 1/2, 1/3, and 1/4?  Thank you.
Thanks, I'm glad I was able to help.
