3570G Stack issues
nathan@hbni.net
   I`m fairly new to all of this and I need a bit of help with a problem that I ran into recently..
I have 2 3750G Cisco switches in a Stack that I`m using as Layer 2 switches for distribution purposes. The problem that I`m having is that anything that I`m plugging into switch 2 (which is the stack member) seems to be having issues as far as connectivity is concerned. I have 2 3560s that are up linked to the stack member and both of those cant be discovered by Cisco Network Assistant. Also my AP are dissociating and associating and when I plug into the Stack master these problems go away, so I`m assuming it has something to do with the stack configuration..
Any help would be appreciated
8 Replies 8
Leo Laohoo
Do the following:
1.  Command:  test cable tdr int <PORT>;
2.  Wait for about 5 to 7 seconds for the process to run it's course;
3.  Command:  sh cable tdr int <PORT>;
4.  Post the complete output to #3.
I guess I should have mention that both of these switches are Fiber switches and the TDR command only works for ethernet ports
Well, I didn't know they were fibre optic.
So let's try something else. Post the complete output to the command "sh interface <PORT> controll".
Here int the output for the show interface G 2/0/1. Thats on the stack member on a port that one of the 3560s is connected to..
GigabitEthernet2/0/1 is up, line protocol is up (connected)
Hardware is Gigabit Ethernet, address is 0011.5c5b.ed81 (bia 0011.5c5b.ed81)
Description: Trunk to Kitchen
MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
Keepalive not set
Full-duplex, 1000Mb/s, link type is auto, media type is 1000BaseSX SFP
input flow-control is off, output flow-control is unsupported
Last input 00:00:58, output 00:00:50, output hang never
Queueing strategy: fifo
Output queue: 0/40 (size/max)
7100948 packets input, 935383004 bytes, 0 no buffer
Received 3480388 broadcasts (3424406 multicasts)
560 input errors, 2 CRC, 0 frame, 0 overrun, 0 ignored
0 watchdog, 3424406 multicast, 0 pause input
10389809 packets output, 5958888688 bytes, 0 underruns
0 output errors, 0 collisions, 1 interface resets
Can I see the output to the command "sh interface <PORT> controll" from the 3560 side?
Below is the output from the 3560 interface
GigabitEthernet0/1 is up, line protocol is up (connected)
Hardware is Gigabit Ethernet, address is 0022.bd6f.0f19 (bia 0022.bd6f.0f19)
Description: trunk to eshop
MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
Keepalive not set
Last input 00:00:00, output 00:00:00, output hang never
5 minute input rate 9000 bits/sec, 8 packets/sec
5 minute output rate 2000 bits/sec, 4 packets/sec
1735229 packets input, 445303594 bytes, 0 no buffer
Received 432395 broadcasts (285891 multicasts)
0 watchdog, 285891 multicast, 0 pause input
1468104 packets output, 188100340 bytes, 0 underruns
0 unknown protocol drops
0 lost carrier, 0 no carrier, 0 pause output
What are the uptimes of the two switches?
The up time on the 3750 stack is 12 days.
while the Uptime on the other one is just a couple of days
