3640 & 3640A
amansoi_5
Level 6
Level 6
Dear All,
What is the difference between 3640 & 3640A router ? how to check which whether it is 3640 or 3640A using cisco command ?
regds,
aman
wong34539
Level 11
Level 11
think, the only difference between the 3640 and 3640A is the PCI bridge version.
you may use the show version command, the platform would be displayed in this command output.
3640A
cisco 3640-A (R4700) processor (revision 0x00) with 91136K/7168K bytes of
memory
3640
cisco 3640 (R4700) processor (revision 0x00) with 93184K/5120K bytes of
memory.
