3640 logging
admin_2
Level 3
Level 3
Try to log the 3640 to a syslog server with "logging hostname", the the 3640 only takes ip address not DNS name. Any one has any insight ?
TIA
Kevin Dorrell
Level 10
Level 10
Did you define a DNS server and domain name where to look it up?
In fact, even if you define a static ip host entry for the logging host, and then do logging hostname, when you read back the config it is an IP address. It only resolves the hostname as you are typing in the command, not dynamically.
Kevin Dorrell
Luxembourg
Thanks kevin. i'm new to this - do you have the command to define the DNS server and Domain name ?
Phillip
ip name-server X.X.X.X
ip domain-lookup
