3650 management interface aaa authentication
harolddauncey
Visitor
Hello everyone!
I am having a really odd issue while attempting to setup some 3650s. We would like to use these switches as dmz/ external switches for layer 2 distribution of Internet and dmz vlans. We are trying to set up management access on the management interface and can't get aaa to work.  We use a simple radius server config for authorization but it just will not work. Called tac and after hours, they said that aaa auth isn't supported on mgmt interface because the interface has to belong to the mgmt-vrf. For some reason I have a hard time believing this. Has anyone else run into this problem? Also what about tacacs? Is that also a limitation on the management interface?
Thanks for any and all help!!!
Harold
What your doing will work as we have it setup , all our mgmt traffic is segragated as best practice these days , ios-xe and ns-ox are all set like this now for mgmt traffic to isolate it through vrf
dont forget your default route as well for the MGMT interface
ip route vrf Mgmt-vrf 0.0.0.0 0.0.0.0 x.x.x.x
interface GigabitEthernet0/0
 description ** Network Managment Interface **
 vrf forwarding Mgmt-vrf
 ip address x.x.x.x 255.255.255.0
aaa authentication login default group xxxx+ local enable
aaa authentication enable default group xxxx+ enable
aaa authorization exec default group xxxx+ local
aaa accounting exec default start-stop group xxxx+
aaa group server tacacs+ xxxx+
 server x.x.x.x
 ip vrf forwarding Mgmt-vrf
vrf definition Mgmt-vrf
 address-family ipv4
 exit-address-family
 address-family ipv6
 exit-address-family
and if you want other MGMT traffic like NTP you source from the vrf
ntp source GigabitEthernet0/0
ntp server vrf Mgmt-vrf x.x.x.x
5 Replies 5
Reza Sharifi
Hi Harold,
What TAC told you is correct.  If you are trying to use the out-of-band management interface of the switch, it has to be in mgmt-vrf. If you have extra regular ports, you can use any of them and use it as a management port.
I understand that it has to be in the mgmt vrf. I'm just confused if you can or can't perform tacacs or aaa over the interface. Isn't it a little odd that on a management port you can't do management tasks using such technologies as tacacs or radius aaa?
For tacacs try smoething like this
 server-private xx.xx.xx.xx key 7 13472043243F332638261863263652
 ip tacacs source-interface GigabitEthernet0/0
 server x.x.x.x
 address-family ipv4
 exit-address-family
 address-family ipv6
 exit-address-family
Awesome! That was it. Cleaned out all of the aaa config and used this example. Works like a charm. Thanks so much for the great info!
