3650 NAT Problem?
Ela Snessjna
I have a brand new switch that I can't seem to get up and running for days now.
I have configured 2 ports of a 3650 . One port is on the outside 1/0/4 and one port is the inside of my network 1/0/5.
Port 1/0/5 is a trunk port with only vlan 60 for the moment. I have a DHCP pool for VLAN 60. (10.60.1.0/25). The Vlan on the switch has IP 10.60.1.1 and this address is used as gateway in the Vlan) Addresses 1 to 10 are excluded from the range.
Port 1/0/4 is a port connected to the internet through DHCP from the provider.
Port 1/0/4 get an internet IP address. Clients connected through port 1/0/5 get IP addresses in the range 10.60.1.0/24
From the client I can ping 10.60.1.1, and I can ping the internet address on 1/0/4.
I have NAT enabled. From the router I can ping everywhere. I can't ping from the clients to the outside of the network.
This is my configuration. At the end I've pasted my show ip route
Current configuration : 4849 bytes
! Last configuration change at 20:30:49 UTC Fri Dec 19 2014
version 15.0
service config
no service pad
service compress-config
hostname router01
boot-start-marker
boot-end-marker
vrf definition Mgmt-vrf
 address-family ipv4
 exit-address-family
 address-family ipv6
 exit-address-family
enable secret 5 xxxxxxxxxxx
username administrator privilege 15 password 0 xxxxxxxxxxx
no aaa new-model
switch 1 provision ws-c3650-24ts
ip routing
no ip domain-lookup
ip device tracking
ip dhcp excluded-address 10.50.1.1 10.50.1.10
ip dhcp excluded-address 10.60.1.1 10.60.1.10
ip dhcp pool urbancity_dynamic01
 network 10.60.1.0 255.255.255.0
 domain-name bpost.urbancity.be
 dns-server 8.8.8.8
 default-router 10.60.1.1
diagnostic bootup level minimal
spanning-tree mode pvst
redundancy
 mode sso
class-map match-any non-client-nrt-class
  match non-client-nrt
policy-map port_child_policy
 class non-client-nrt-class
    bandwidth remaining ratio 10
interface GigabitEthernet0/0
 vrf forwarding Mgmt-vrf
 no ip address
 negotiation auto
interface GigabitEthernet1/0/1
 description Upload
 no switchport
 ip address 10.2.1.43 255.255.0.0
 shutdown
interface GigabitEthernet1/0/2
 shutdown
interface GigabitEthernet1/0/3
 shutdown
interface GigabitEthernet1/0/4
 no switchport
 ip address dhcp
 no ip redirects
 ip nat outside
interface GigabitEthernet1/0/5
 switchport trunk native vlan 60
 switchport trunk allowed vlan 60
 switchport mode trunk
interface GigabitEthernet1/0/6
interface GigabitEthernet1/0/7
interface GigabitEthernet1/0/8
interface GigabitEthernet1/0/9
interface GigabitEthernet1/0/11
interface GigabitEthernet1/0/12
interface GigabitEthernet1/0/13
interface GigabitEthernet1/0/14
interface GigabitEthernet1/0/15
interface GigabitEthernet1/0/16
interface GigabitEthernet1/0/17
interface GigabitEthernet1/0/18
interface GigabitEthernet1/0/19
interface GigabitEthernet1/0/20
interface GigabitEthernet1/0/21
interface GigabitEthernet1/0/22
interface GigabitEthernet1/0/23
interface GigabitEthernet1/0/24
interface GigabitEthernet1/1/1
interface GigabitEthernet1/1/2
interface GigabitEthernet1/1/3
interface GigabitEthernet1/1/4
interface Vlan1
 ip address dhcp
 shutdown
interface Vlan60
 ip address 10.60.1.1 255.255.255.0
 no ip redirects
 ip nat inside
ip nat inside source list 10 interface GigabitEthernet1/0/4 overload
ip http server
ip http authentication local
ip http secure-server
access-list 10 permit any
line con 0
 stopbits 1
line aux 0
line vty 5 15
wsma agent exec
 profile httplistener
 profile httpslistener
wsma agent config
wsma agent filesys
wsma agent notify
wsma profile listener httplistener
 transport http
wsma profile listener httpslistener
 transport https
ap group default-group
end
router01#show ip route
Codes: L - local, C - connected, S - static, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2
       i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, * - candidate default, U - per-user static route
       o - ODR, P - periodic downloaded static route, H - NHRP, l - LISP
       + - replicated route, % - next hop override
Gateway of last resort is 84.196.224.1 to network 0.0.0.0
S*    0.0.0.0/0 [254/0] via 84.196.224.1
      10.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
C        10.60.1.0/24 is directly connected, Vlan60
L        10.60.1.1/32 is directly connected, Vlan60
      84.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
C        84.196.224.0/20 is directly connected, GigabitEthernet1/0/4
L        84.196.227.XXX/32 is directly connected, GigabitEthernet1/0/4
5 Replies 5
Jon Marshall
Are you sure these switches support NAT ?
I did see the post in WAN that you added to and i posted a comment in there about them not supporting NAT then noticed that the OP actually had a debug showing NAT occurring when he pinged directly from the switch itself.
So I edited the post but still have doubts as to whether this switch supports it for clients.
I have checked the configuration guides and can't find any mention of NAT anywhere.
Do you have any documentation that says it is supported ?
Jon
I assumed it did? Otherwise I have a big problem :/
It certainly does NAT on the local interfaces.
router01#ping
Protocol [ip]:
Target IP address: 8.8.8.8
Repeat count [5]:
Datagram size [100]:
Timeout in seconds [2]:
Extended commands [n]: y
Source address or interface: 10.60.1.1
Type of service [0]:
Set DF bit in IP header? [no]:
Validate reply data? [no]:
Data pattern [0xABCD]:
Loose, Strict, Record, Timestamp, Verbose[none]:
Sweep range of sizes [n]:
Sending 5, 100-byte ICMP Echos to 8.8.8.8, timeout is 2 seconds:
Packet sent with a source address of 10.60.1.1
Success rate is 100 percent (5/5), round-trip min/avg/max = 10/16/20 ms
router01#show ip nat translations
Pro Inside global      Inside local       Outside local      Outside global
icmp 84.196.227.XXX:1025 10.60.1.1:12     8.8.8.8:12         8.8.8.8:1025
That is the weird thing because the other poster could also do that.
The only catalyst switch that I know of that supports NAT is the 6500 (don't know about the 6800 as I have never used it).
So I assumed it wouldn't support it. That is why I asked if you had any supporting documentation.
The results you posted above are surprising but I would still tend to think it is not supported.
Unfortunately I can't say for sure because I haven't used that switch so I guess we'll have to hope either the OP in the other thread comes back with an answer or someone else on the forum knows.
Jon
I do think we are getting close.. http://www.cisco.com/c/en/us/support/docs/ip/network-address-translation-nat/29283-166.html
Doesn't state the 3650 but does state the 3750 and 3560.
Hm this is a problem for me. I need a device where I can connect two wans so I can route  and NAT the traffic accordingly the vlan.
Some end device just for the NATting and firewalling maybe?
Thanks!
Jon is correct.  Only the 6500 series can do nat.  All the other devices (3560, 3750, 3850, 3650, 4500) series do not support nat.
You need a router or firewall to do this function for you.
