WS-C3650-24TS-L with lan base image it support intervlan routing or  not ?
I recently check this for us and lan base only supports static routes on SVIs. please refer to the configuration guide (pg 45)
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3650/software/release/3se/vlan/configuration_guide/b_vlan_3se_3650_cg.pdf
http://www.cisco.com/c/en/us/products/collateral/switches/catalyst-3650-series-switches/q-and-a-c67-729531.html (Refer table 3)
***Please rate all the useful posts***
-Prabath
i think it can be according to the configuration guide ,right  ?
