3745 Router will not hold configuration
DReeves12
I have a 3745 Router that will not hold its configuration. I have tried:
Reloading the IOS, re-seeding the flash card and RAM.
Any ideas on what I should replace first?
Latchum Naidu
You no need to replace anything...
Please check the config register which should be like below....
Set the configuration register to 0x2102 and reload the router:
rommon 1 >confreg 0x2102
rommon 2 >reset
If still your issue is not resolved please open a TAC case immediately...
Please rate if this helped you...
Naidu.
