3750 High output drops and performance issues
n
I am experiencing performance issues with 3750 12.2(50)SE3.
On some interfaces transmit utilization is 100% and have a lot of output drops. It doesn't depend on if it is IPTV, VoIP or normal Access point. As a temporary solution i reconnect cable to unused port and copy same config to a new port.
LSW-11_02#sh ver
Cisco IOS Software, C3750 Software (C3750-IPBASEK9-M), Version 12.2(50)SE3, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Wed 22-Jul-09 06:19 by prod_rel_team
Image text-base: 0x01000000, data-base: 0x02900000
ROM: Bootstrap program is C3750 boot loader
BOOTLDR: C3750 Boot Loader (C3750-HBOOT-M) Version 12.2(44)SE5, RELEASE SOFTWARE (fc1)
PAAC-HO-LSW-11_02 uptime is 2 weeks, 6 days, 19 hours, 36 minutes
System restarted at 18:59:03 ACHGABAT Mon Jun 29 2015
System image file is "flash:c3750-ipbasek9-mz.122-50.SE3/c3750-ipbasek9-mz.122-50.SE3.bin"
11 Replies 11
n
LSW-11_02#sh interfaces f3/0/9
FastEthernet3/0/9 is up, line protocol is up (connected)
  Hardware is Fast Ethernet, address is 0026.523f.4e0b (bia 0026.523f.4e0b)
  Description: * IPTV *
  MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
     reliability 255/255, txload 247/255, rxload 1/255
  Keepalive set (10 sec)
  Full-duplex, 100Mb/s, media type is 10/100BaseTX
  input flow-control is off, output flow-control is unsupported
  Last input never, output never, output hang never
  Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 758813644
  Queueing strategy: fifo
  Output queue: 0/0 (size/max)
  5 minute output rate 98768000 bits/sec, 9071 packets/sec
     272295 packets input, 25607925 bytes, 0 no buffer
     Received 173115 broadcasts (173070 multicasts)
     0 watchdog, 173070 multicast, 0 pause input
     5783600419 packets output, 7849261836953 bytes, 0 underruns
     0 output errors, 0 collisions, 1 interface resets
See if this has anything relevance here:
https://tools.cisco.com/quickview/bug/CSCtq86186
CSCtq86186 bug is only shows incorrectly output drops but i have also issues with performance.
Looking at the above output, it is clear that the interface is taking more than what it physically send over the wire. If the utilization that high, you cannot do anything than changing to a gig port.
However one thing i clearly notice is the below
This makes me believe that there could be some kind of flooding happening on the network. Check for any interface whose input rate is abnormally high and try to shut it down if it is not expected to send that much traffic. Also check for spanning tree stability. Enable mac move notification to check if any loop is occurring.
conf t# mac address table notification mac-move
Hope this helps you,
Madhu.
****rating encourages participation*****
One more thing is you can try to sniff using SPAN to see what it is sending out. Probably it may give us information about what is the source of it.
Madhu
n
LSW-11_02#show run interface f3/0/9
interface FastEthernet3/0/9
 description * IPTV *
 switchport trunk native vlan 300
 switchport trunk allowed vlan 10,300
 switchport mode trunk
 switchport nonegotiate
 ip arp inspection limit rate 30
 srr-queue bandwidth share 1 70 25 5
 srr-queue bandwidth shape 3 0 0 0
 priority-queue out
 storm-control broadcast level 1.00
 storm-control action shutdown
 no cdp enable
 spanning-tree portfast trunk
 service-policy input QOS_POLICY
n
LSW-11_02#sh controllers ethernet-controller f3/0/9
     Transmit FastEthernet3/0/9               Receive
   3577533299 Bytes                         25640553 Bytes
       351373 Unicast frames                   99342 Unicast frames
   1499002000 Multicast frames                173179 Multicast frames
     12275487 Broadcast frames                    45 Broadcast frames
            0 Too old frames                14226181 Unicast bytes
            0 Deferred frames               11411492 Multicast bytes
            0 MTU exceeded frames               2880 Broadcast bytes
            0 1 collision frames                   0 Alignment errors
            0 2 collision frames                   0 FCS errors
            0 3 collision frames                   0 Oversize frames
            0 4 collision frames                   0 Undersize frames
            0 5 collision frames                   0 Collision fragments
            0 6 collision frames
            0 7 collision frames               36207 Minimum size frames
            0 8 collision frames              229752 65 to 127 byte frames
            0 9 collision frames                   0 128 to 255 byte frames
            0 10 collision frames                  0 256 to 511 byte frames
            0 11 collision frames                  2 512 to 1023 byte frames
            0 12 collision frames               6605 1024 to 1518 byte frames
            0 13 collision frames                  0 Overrun frames
            0 14 collision frames                  0 Pause frames
            0 15 collision frames
            0 Excessive collisions                 0 Symbol error frames
            0 Late collisions                      0 Invalid frames, too large
            0 VLAN discard frames                  0 Valid frames, too large
            0 Excess defer frames                  0 Invalid frames, too small
      2636179 64 byte frames                       0 Valid frames, too small
     16720917 127 byte frames
      2234964 255 byte frames                      0 Too old frames
       329764 511 byte frames                      0 Valid oversize frames
       315863 1023 byte frames                     0 System FCS error frames
   1489389486 1518 byte frames                     0 RxPortFifoFull drop frame
         1687 Too large frames
            0 Good (1 coll) frames
            0 Good (>1 coll) frames
n
LSW-11_02#sh mls qos
QoS is disabled
QoS ip packet dscp rewrite is enabled
n
Uplink is :
LSW-11_02#sh interfaces gi1/0/1 | i tx
     reliability 255/255, txload 1/255, rxload 66/255
Any kind of help is appreciated.
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
The 3560/3750 (and 2960 too) series is a bit infamous for dropping packets on congested ports.  This because these switches don't have a lot of buffer RAM resources, and how they manage it, can be very suboptimal in some situations.
The 3750 has 2 MB of RAM per 24 copper ports and per its uplink ports, so placement of "busy" ports can be important.
Enabling QoS, but running with its default settings, often leads to many drops.  You note in another posting that QoS is disabled, which is often a good first step, if QoS isn't needed, but I've found you can sometimes get the best results if you enable QoS and manually tune the buffer settings.
If only some ports are busy, and bursty, I've found setting up buffering to work from the common pool can often greatly reduce drops.
n
We found out that problem was only with IPTV(multicast packets).
For unknown reason core swtich(6509) doesn't query with igmp snooping querier and swtiches just flood all joined multicast groups' packets to interfaces.
We have enabled ip igmp snooping querier on all access layer switches solve this problem.
Thanks all for your suggestions.
