3750 questions
martone-mtsiss
Hi I am still getting familiar with Cisco products
Can I put a Fiber Optic MM cable into a 24-port 3750 switch? Also if I want to gang 2 3750s together (48-port) what is the best way to do this?
ralphcarter
You need a 3750 switch with SFP Ports for the fiber.
Multimode cable uses SX, you need: 1000BaseSX SFP Model: GLC-SX-MM for the 3750 switch with SFP ports
To connect the switches in the best way possible, use the Stackwise Cable. Connect both stack ports to both switches for full duplex operation.
CCIE 26175
www.techsnips.com
