3750 stack issue
Cisco Freak
Level 9
Level 9
I have two Cisco 3750 switches configured in stack.
Switch#sh switch
Switch/Stack Mac Address : 001b.8f73.5580
                                           H/W   Current
Switch#  Role   Mac Address     Priority Version  State
 1       Member 001b.543e.6780     15     0       Ready
*2       Master 001b.8f73.5580     1      0       Ready
I see that switch 1 has a priority of 15. Still its not the switch master. Please help me to understand why Switch1 is not becoming master.
Also, in the running config I don't see anywhere we configure the switch priority as 15. I am wondering how it became 15 without configuration.
Switch#sh run | i priority
Switch#remote command 1 sh run | i priority
Switch : 1 :
Switch#
CF
7 Replies 7
Hello
Have you recently performed priority change or install of a new switch to the stack are they running the same ios and feature set?
Have you tried reloading the stack?
sh switch detail
sh version
res
Paul
Kind Regards
Paul
No, I have't tried reloading the switch. Both swithches are switch same IOS and feature set.
Switch#sh switch detail
                                           H/W   Current
         Stack Port Status             Neighbors
Switch#  Port 1     Port 2           Port 1   Port 2
  1        Ok         Ok                2        2
  2        Ok         Ok                1        1
Switch#sh ver
Cisco IOS Software, C3750 Software (C3750-IPBASEK9-M), Version 12.2(55)SE4, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Tue 06-Sep-11 02:59 by prod_rel_team
Image text-base: 0x01000000, data-base: 0x02D00000
ROM: Bootstrap program is C3750 boot loader
BOOTLDR: C3750 Boot Loader (C3750-HBOOT-M) Version 12.2(44)SE5, RELEASE SOFTWARE (fc1)
Switch uptime is 10 weeks, 6 days, 9 hours, 47 minutes
System restarted at 00:16:52 Pacific Thu Sep 3 2015
System image file is "flash:/c3750-ipbasek9-mz.122-55.SE4.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
[email protected].
cisco WS-C3750G-24TS-1U (PowerPC405) processor (revision E0) with 131072K bytes of memory.
Processor board ID FOC1113Y14U
Last reset from power-on
3 Virtual Ethernet interfaces
56 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address       : 00:1B:8F:73:55:80
Motherboard assembly number     : 73-10219-07
Power supply part number        : 341-0098-02
Motherboard serial number       : FOC1107121V
Power supply serial number      : AZS110703WF
Model revision number           : E0
Motherboard revision number     : B0
Model number                    : WS-C3750G-24TS-S1U
System serial number            : FOC1113Y14U
Top Assembly Part Number        : 800-26859-01
Top Assembly Revision Number    : C0
Version ID                      : V03
CLEI Code Number                : CNMWS00ARC
Hardware Board Revision Number  : 0x09
Switch Ports Model              SW Version            SW Image
     1 28    WS-C3750G-24TS-1U  12.2(55)SE4           C3750-IPBASEK9-M
*    2 28    WS-C3750G-24TS-1U  12.2(55)SE4           C3750-IPBASEK9-M
Switch 01
Switch Uptime                   : 10 weeks, 6 days, 8 hours, 22 minutes
Base ethernet MAC Address       : 00:1B:54:3E:67:80
Motherboard serial number       : FOC11105719
Power supply serial number      : AZS1109067V
System serial number            : FOC1111Y1KH
Top assembly part number        : 800-26859-01
Top assembly revision number    : C0
Version ID                      : V03
Configuration register is 0xF
Switch#
Please see this extract from
http://www.cisco.com/c/en/us/support/docs/switches/catalyst-3750-series-switches/71925-cat3750-create-switch-stks.html#election
When is the stack master elected?
  • When the whole switch stack is reset1
  • When the stack master is reset or powered off
    Note: If you reset the stack master, it would reset the whole stack.
  • When the stack master is removed from the stack
  • When the stack master switch has failed
  • The switch stack membership is increased by if you add powered-on standalone switches or switch stacks.1
1Within these events, the current stack master has a greater chance to get re-elected.
Hello
Can i suggest reload the stack when applicable
res
Paul
Kind Regards
Paul
Yes, I can do it.
But I want to replace the switch 1 with a new one. I am wondering if I replace it with a new one, whether it will sync the config from the current master which is switch 2.
CF
Hello
It looks like switch 1 one was powered up first, and then switch 2 but was they connected when you powered the 2nd switch up or did you just attach it whilst it was powered on?
I would reboot the stack and then if you wish remove the whatever switch you wish then renumber one you wish to keep and the one you wish to remove and then disconnect the old switch and unprovison it.
res
Paul
Kind Regards
Paul
When a switch joins a stack it will get the current config from the stack,all switches in a stack have a copy of the configuration of the stack. To be on the safe side you can delete the config and vlan.dat of the switch you are going to add to the stack.
I have nver had any problems replacing switches in a stack it all works well
