3750 stack switch
If I replace 3750 48 gigabit switch with a 3750 24 fast ethernet switch in the stack will the port configuration apply from the 48 port switch to the 24 port, also if I replace a 3750 48 switch with a identical 3750 48 switch will the port configuration apply exactly.  Keep in mind this switches are the members not the master.
Reza Sharifi
If you replace a 48 port switch with the same exact model with 48 port, you should be fine.  To go from a 3750 48 Gig to 3750 24 fast, you need to deleted the 48 port from the stack and then add the 24 port.
