3750 switch master command
BRUNO WOLLMANN
Level 2
Level 2
Hi All,
I'm sending out a quick question to verify that there is no command to manually cause a member switch to become master.  The only way to change the master is by reloading it.  Is this correct?
I know I can change switch priorities and influence which switch will become master when I reload the entire stack but there doesn't appear to be a way to change masters in a running stack without a reload.
Bruno
shailesh.h
Level 5
Level 5
Reference:      http://www.cisco.com/en/US/products/hw/switches/ps5023/products_configuration_example09186a00807811ad.shtml
Master will be re-elected when
  • When the whole switch stack is reset1
  • When the stack master is reset or powered off
    Note: If you reset the stack master, it would reset the whole stack.
  • When the stack master is removed from the stack
  • When the stack master switch has failed
  • The switch stack membership is increased by if you add powered-on standalone switches or switch stacks.1
So your understanding is correct that you cannot make other switch master till you reload the stack...
shailesh.h
Level 5
Level 5
