3750 Trunk and qos
wim_depauw
I would like to implement qos on a trunk between 2 3750 switches . I configured a police map which should police the ftp traffic but it doesn't seem to work.
I see that my access-lists are not matched for the ftp traffic . Is this because it is a trunk ?
When I replace the ftp statement by an ip statement it works fine.
PS : I'm using an dot1q trunking.
gr
wim
mfreijser
Can you post the configuration of the switch? You can let out the unusefull information and passwords! (we don't need to see every ethernet interface and your passwords ;) )
That way we can look for configuration-errors or suggestions for your configuration.
Michael
