3750 vs 3750v2
Kurt Lei
I am newbie on networking. My boss asked me to replace Cisco 3750 to Cisco 3750v2 at the remote office. I have to issue the new configuration on 3750v2. I would like to ask is the configuration compatible between 3750 and 3750v2 ?
Thanks Guy ~~
Ashok Kumar
Command line is same for both switches, but at hardware level there's new technologies in V2 switches.
Below article will help:
Cisco Catalyst 3750 v2 Series are next-generation energy-efficient Layer 3 Fast Ethernet stackable switches. These new switches support Cisco EnergyWise technology, which helps you manage the power consumption of your network, thereby reducing energy costs and carbon footprint. And the Cisco Catalyst 3750 v2 Series consumes less power than its predecessors and is an ideal access layer for enterprise, retail, and branch environments. It helps increase productivity and protects your network investment by providing a unified network for data, voice, and video.
What are the MAIN differences between the lines of Cisco 3750 series switches? Now we list a brief overview of the biggest differences between the Cisco 3750 V2, Catalyst 3750-E, and the Cisco 3750-X.
Network Modules
There are four network modules for the 3750-X. Each provides a combination of GbE or 10GbE interfaces. For upgrade protection and scalability we often find ourselves deploying the four port network modules that support either four GbE or two 10GbE. This allows a customer to utilize existing GbE connectivity and later upgrade to 10GbE.
The Cisco 3750-E supports the TwinGig SFP converter. This enables an upgrade path from 1GbE to 10GbE.
StackWise Technology
StackWise technology allows a group of 3750 switches to be “stacked” together using StackWise cables. This stacking of switches basically combines them into one functional unit providing much higher levels of redundancy and capacity while providing investment protection. Since switches can be added to the stack you can “pay as you grow”. StackWise backplanes rates are 32Gbps and up to 9 switches can participate in a stack. Keep in mind these rates assume that all switches are connected with two cables. For example, if you connect two 3750s together with one StackWise cable you will only achieve a rate of 16Gbps.
StackWise Plus
Built on StackWise technology, StackWise Plus offers several improvements in speed and performance. StackWise Plus offers 64Gbps backplane across the StackWise cables (backplane). Up to nine switches can be in the stack. Performance is also enhanced with “local switching” of packets. With StackWise technology packets had to traverse the full ring regardless of destination. StackWise Plus eliminates this and once the packet finds its destination it no longer traverses the entire ring
- Ashok
Please rate the post or mark as correct answer as it will help others looking for similar information
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Configuration compatibility, from a 3750 to 3750v2, depends on what IOS versions and feature sets the two switches are running.  Generally a higher version and/or better feature version will "digest" the other's configuration.
With 3750s, you might also run into port/interface naming differences if one switch's copper edge ports are FE and the other's are GE.
Aureliano
If you talk about 3750, not 3750G, the main difference about configuration, is IOS compatibility. 3750 support only 12. IOS while 3750v2 supports 15. IOS. It is just because 3750 simply don't have enough flash memory to install and run 15. IOS
