3750-X not recognizes in 3750G STACK
Lorenzo469
Hello Guys,
I just tried to add a 3750x to 3750G stack but unfortunately the 3750X is not recognized by the Stack.
I don't understand why the 3750X is not recognized by the 3750G Stack, do you have any ideas what could be the problem ?
The aim is ton obtain a Stack like this 3x 3750G + 1x 3750X.
Log on the 3750 G Stack
#Show Run
switch 1 provision ws-c3750g-24ps
switch 2 provision ws-c3750g-48ps
switch 3 provision ws-c3750g-48ps
switch 4 provision ws-c3750x-48p
Switch Ports Model              SW Version            SW Image
*    1 28    WS-C3750G-24PS     12.2(55)SE9           C3750-IPBASEK9-M
     2 52    WS-C3750G-48PS     12.2(55)SE9           C3750-IPBASEK9-M
     3 52    WS-C3750G-48PS     12.2(55)SE9           C3750-IPBASEK9-M
WAT-BESW110#show switch stack-ports
  Switch #    Port 1       Port 2
    1           Ok          Down  ==> Stack cable patched to the 3750 X
    2           Ok           Ok
    3          Down  ===> Stack cable patched to the 3750 X        Ok
#show switch
Switch/Stack Mac Address : 0018.1959.d080
                                           H/W   Current
Switch#  Role   Mac Address     Priority Version  State
*1       Master 0018.1959.d080     15     0       Ready
 2       Member 0018.18e8.6b00     2      0       Ready
 3       Member 0018.18e8.5f00     1      0       Ready
 4       Member 0000.0000.0000     0      1       Provisioned
Log on the 3750 X
Show version
*    1 54    WS-C3750X-48P      12.2(55)SE9           C3750E-IPBASEK9-M
Switch#show switch stack-ports
    1          Down         Down
Many thanks in advance dor your help.
Joseph W. Doherty
What's the license on the 3750X?
Sorry for the delay Joseph.
Switch#show license
Index 1 Feature: ipservices
        Period left: 0  minute  0  second
Index 2 Feature: ipbase
Index 3 Feature: lanbase
        Period left: Life time
        License Type: Permanent
        License State: Active, In Use
        License Priority: Medium
        License Count: Non-Counted
Thanks for your help
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
If I'm reading the license information correctly, you've only have a LANBase license, which, I believe, will only stack with other LANBase stack members.  I.e. you may need to upgrade your 3750X to IPBase.
I think this should work only if the all switches members are running the same version of IOS (12.2(55)SE9 for instance) with the following difference meanwhile 3750X in "UNIVERSALK9" and 3750G in "IPSERVICESK9".
