3750x upgrade from 12.2(55)SE7 to 15.2.4E7 MD
krisvamcee
Hi all,
I would like to upgrade Cisco 3750x from 12.2(55)SE7 to 15.2.4E7 MD and I would like to confirm if we can jump from 12.2 to 15.x version?
Also please advise if anybody saw any issues going to this new version.
Kris
9 Replies 9
luis_cordova
Hi @krisvamce,
I recommend you make a gradual update until the IOS you want.
Sometimes, a direct jump gets compatibility problems.
Thanks Luis, which IOS version do you suggest?
Kris
Hi @krisvamcee,
You could start updating to the highest version of IOS 12.2
Then jump to the lowest version of IOS 15.2
Finally, upgrade to the newest version.
Remember to check that the versions are always compatible with the hardware of your device.
Thanks Luis
Reza Sharifi
This is the latest IOS posted and also suggested by Cisco.
c3750e-universalk9-mz.152-4.E7.bin
You should be fine as long as you have enough memory and flash space which is 256/64
Good Luck!
Thanks Reza
Leo Laohoo
You can jump direct to 15.X.
Make sure you read the Release Notes carefully.
Be warned that there will be a bootstrap upgrade and this will take, approximately, 45 minutes.
Thanks Leo, I believe the bootstrap upgrade will be done automatically.
I have checked the below link for release notes and under supported hardware I see we are running the higher IOS than the recommeded IOS to perform an upgrade. Please let me know if I have to consider anything else.
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3750x_3560x/software/release/15-2_4_e/releasenotes/rn-1524e-3750x3560x.html#31742
Kris
Yes, for the smaller switches (3560, 3750, 3750x, 3850, etc..) the bootstrap will be upgraded as part of the IOS. Just be prepared for a long time for the device to load.  I think it takes about 17 minutes for the new IOS to load. So, don't panic if it takes a long time to reboot.  Also, make sure your maintenance window is long enough to accommodate the reboot time and verification.
And one more thing, make sure to back up the config before upgrading.
