3800 Series NME BAUD rate
My NME wasn't loading it's IOS properly so we were attempting to XModem a new IOS to it. To speed up the process I changed the BAUD to 38400 using "set BAUD 38400". Now, even after changing both the BAUD rates on the router itself and my putty/hyperterm session, I still get the "wingdings" associated with an incorrect BAUD rate. Is there a way I can reset or reconfigure the NME to use the default 9600 again??
Seb Rupik
Hi there,
Have you tried editing the config register value in ROMMON?
http://www.cisco.com/c/en/us/support/docs/routers/3600-series-multiservice-platforms/22189-pswdrec-3600.html
...then:
rommon 1 >confreg 0x2102
rommon 2 >reset
If it boots and still has the wrong baud rate, boot back into rommon and type:
rommon 1 >confreg 0x2142
rommon 2 >reset
This will bypass your startup config. Copy the startup-config to running-confg and edit the console port settings:
line con 0
speed 9600
write mem & reload
cheers,
Seb.
I haven't tried ROMMON on the router itself, because the issue is with the switch module within the router. I can access the router perfectly fine, but when I access the switch module...
Router# service-module g2/0 session
 .... it connects with the switch module, but gives me a gibberish output.
