3845/2821 power consumption
brian.kennedy
Is there a command on the 3845's or 2821's to show actual power consumption (as in the show power on 65's or show power inline on a 3560?
Collin Clark
Not sure if this helps, but
Router# show environment
Redundant Power System is not present.
SYS PS1 is present.
Type: AC
AUX (-48V) PS1 is absent.
Fan 1 Normal
Fan 2 Normal
Fan 3 Normal
Fan Speed is Normal
Alert settings:
Intake temperature warning: Enabled, Threshold: 50
Core temperature warning: Enabled, Threshold: 70 (CPU: 95)
Board Temperature: Normal
Internal-ambient temperature = 29, Normal
CPU temperature = 46, Normal
Intake temperature = 31, Normal
Voltage 1(3300) is Normal, Current voltage = 3316 mV
Voltage 2(5150) is Normal, Current voltage = 5210 mV
Voltage 3(2500) is Normal, Current voltage = 2525 mV
Voltage 4(1200) is Normal, Current voltage = 1191 mV
http://www.cisco.com/en/US/docs/routers/access/3800/hardware/installation/guide/38troub.html
Collin Clark
SYS PS1 is present.
Type: AC
Fan 1 Normal
Fan 2 Normal
Fan 3 Normal
Fan Speed is Normal
Alert settings:
Yeah, that's what I thought. I was hoping for something else that showed power consumption (watts), but that will have to do.
