3845 router ATM sub-interface Modular QOS
anasubra_2
Hi All,
We were trying to configure Modular QOS on an ATM sub-interface in output direction on a Cisco 3845 router and we get an error message stating CBWFQ not supported on sub-interfaces.The sample config as below
policy-map x
class w
priority percent 20
class y
bandwidth percent 10
We have class-map configured appropriately.
Anantha Subramanian Natarajan
Giuseppe Larosa
Hello Anantha,
have you configured the ATM class of service on the associated PVC ?
if UBR it doesn't allow to use the CBWFQ because it sees the ATM subif without guaranteed BW resources
Hope to help
Giuseppe
Hi Giuseppe,
Thanks for the response,Let me check whether UBR been used on that ATM subif.
Once again thank you very much
lloydardoin
Hi anasubra,
We have several 3845s in our environment doing MQC. They act as ATM hosts for our client edge sites and we then connect to the AT&T network MPLS network to back haul to their perspective HQs. On the MPLS circuits the policy will need to go under the PVC like this.
interface ATM0/IMA1.1 point-to-point
description xxxxxxxxxxxxxxxxxxxx
bandwidth 1216
ip vrf forwarding xxxxxxx
ip address xx.xx.xx.xx 255.255.255.252
pvc 1/32
vbr-nrt 1216 1216 1
tx-ring-limit 3
oam-pvc manage 0
encapsulation aal5snap
service-policy output
On the ATM host side it goes directly under the sub-interface like this..
interface ATM0/IMA0.58 point-to-point
ip address xx.xx.xx.xxx 255.255.255.252
service-policy input
pvc 1/40
HTH,
Lloyd
Hi Lloyd,
Thank you very much for the response. Actually with respect to your scenario,the ATM host side is our Cisco 3845 router having the point-to-point pvc and when we tried to configure the service-policy under the subif,it didn't take the command and gives the message that CBWFQ not supported on the subif,,,,also we tried configure the service-policy under the pvc and it takes the command without any error message but didn't show in the configuration.
