3850 filesystem corruption
b.lancini
Hi ,
Looks like my 3850-24P has a corrupted file system and refuses to complete the boot process from either usbflash0: or network from rom-monitor
I note that flash: is reporting read-only. Does anyone know the correct syntax of the rom-monitor commands to reformat sda1 ?
Anyone seen this before ?
Kind regards - B
---<snip!>--------------------------------------------------
List of filesystems currently registered:
              xmodem[0]: (read-only)
                null[1]: (read-write)
                  bs[3]: (read-only)
           usbflash0[10]: (read-write)
               flash[19]: (read-only)
                tftp[20]: (read-write)
switch: dir flash:
Directory of flash:/
 80801  drwx  4096       .
     2  drwx  4096       ..
 80802  -rw-  2097152    nvram_config
     0  -rw-  2097152    cat3k_caa-base.SPA.03.07.01E.pkg
     0  -rw-  2097152    cat3k_caa-drivers.SPA.03.07.01E.pkg
     0  -rw-  2097152    cat3k_caa-infra.SPA.03.07.01E.pkg
     0  -rw-  2097152    cat3k_caa-iosd-universalk9.SPA.152-3.E1.pkg
     0  -rw-  2097152    cat3k_caa-platform.SPA.03.07.01E.pkg
     0  -rw-  2097152    cat3k_caa-wcm-ldpe.SPA.10.3.110.0.pkg
 80812  -rw-  1236       packages.conf
 80810  drwx  4096       virtual-instance
  8081  drwx  4096       vman_fdb
 16161  drwx  4096       dc_profile_dir
 16163  dr-x  4096       wnweb_store
 80811  -rw-  1250       packages.conf.00-
     0  -rw-  1250       cat3k_caa-base.SPA.03.06.03E.pkg
     0  -rw-  1250       cat3k_caa-drivers.SPA.03.06.03E.pkg
     0  -rw-  1250       cat3k_caa-infra.SPA.03.06.03E.pkg
     0  -rw-  1250       cat3k_caa-iosd-universalk9.SPA.152-2.E3.pkg
     0  -rw-  1250       cat3k_caa-platform.SPA.03.06.03E.pkg
     0  -rw-  1250       cat3k_caa-wcm.SPA.10.2.131.0.pkg
switch: dir sda9:
Directory of sda9:/
     2  drwx  1024       .
     2  drwx  1024       ..
switch: set BOOT usbflash0:cat3k_caa-universalk9.SPA.03.06.03.E.152-2.E3.bin
switch: reset
Are you sure you want to reset the system (y/n)?y
System resetting...
Booting...Initializing RAM +++++++@@@@@@@@...++++++++++++++++++++++++++++++++
Base ethernet MAC Address: f0:78:16:11:03:00
Initializing Flash...
flashfs[7]: 0 files, 1 directories
flashfs[7]: 0 orphaned files, 0 orphaned directories
flashfs[7]: Total bytes: 6784000
flashfs[7]: Bytes used: 1024
flashfs[7]: Bytes available: 6782976
flashfs[7]: flashfs fsck took 2 seconds....done Initializing Flash.
Reading full image into memory....................................................................................................................................................................................................................................................................................................done
Bundle Image
Kernel Address    : 0x6044d274
Kernel Size       : 0x418331/4293425
Initramfs Address : 0x608655a8
Initramfs Size    : 0xe780c1/15171777
Compression Format: .mzip
Bootable image at @ ram:0x6044d274
Bootable image segment 0 address range [0x81100000, 0x82140000] is in range [0x80180000, 0x90000000].
File "usbflash0:cat3k_caa-universalk9.SPA.03.06.03.E.152-2.E3.bin" uncompressed and installed, entry point: 0x8166a500
Loading Linux kernel with entry point 0x8166a500 ...
Bootloader: Done loading app on core_mask: 0xf
### Launching Linux Kernel (flags = 0x5)
EXT2-fs error (device sda1): ext2_check_descriptors: Block bitmap for group 16 not in group (block 195328)!
All packages are Digitally Signed
Starting System Services
Mar 7 19:32:22 %IOSXE-2-PLATFORM: process kernel: EXT2-fs error (device sda1): ext2_check_descriptors: Block bitmap for group 16 not in group (block 195328)!
FIPS(NGWC): Flash Key Check : Begin
FIPS(NGWC): Flash Key Check : End, Not Found, FIPS Mode Not Enabled
BIST failed. Abort init ...
Philip D'Ath
Check out this forum post about how to use the emergency install procedure.
https://supportforums.cisco.com/discussion/11902486/unable-change-boot-file-cisco-3850
