Showing results forĀ
Search instead forĀ
Did you mean:Ā
3850 Flow control questions
Hi Community,
I have some questions on flow control, more in particular on a 3850 switch.
- Can someone clarify the difference between: "flowcontrol receive on" and "flowcontrol receive desired"?
The config guide of the 3850 does not help a lot.
- I have configured "flowcontrol receive on" on an interface but I see the following output, can someone clarify why this is happening?
   Why do I see "Recieve admin" to on and "FlowControl oper" to off?
show int gi 1/0/38:
input flow-control is off, output flow-control is unsupported
show flowcontrol interface gigabitEthernet 1/0/38:
Port Send FlowControl Receive FlowControl RxPause TxPause
        admin oper            admin    oper
Gi1/0/38 Unsupp. Unsupp. on off 50 0
Jose Solano
Level 4
Level 4
Check this out, maybe it can clarify some of your questions:
http://www.cisco.com/c/en/us/td/docs/ios-xml/ios/interface/command/ir-xe-3se-3850-cr-book/define_interface_range_through_interface_range.html?bookSearch=true#wp2433959017
HTH.
