3850 ip routing command and Firewall
Sheraz.Salim
I was setting up a 3850 switch connected with firewall.
here is the setup swtich
vlan 100
vlan 200
vlan 500
interface 100
ip address 192.168.100.254 255.255.255.0
no shut
interface 200
ip address 192.168.200.254 255.255.255.0
no shut
interface vlan 500
ip address 192.168.50.254 255.255.255.0
no shut
interfacec gig 1/0/5
description LINK TO FIREWALL INTERFACE
swtich mode access
swtich access vlan 500
ip route 0.0.0.0 0.0.0.0 192.168.1.253
Firewall
on firewall interface gig 1/0/2
nameif inside
secuirty level 100
ip add 192.168.50.253 255.255.255.0
no shut
route inside 192.168.0.0 255.255.0.0 192.168.50.254
ok from the above setup from firewall i can ping the swtich SVI but at the same time on vlan 100 i have around 5 host connected and i can not ping from firewall to these addresses for example 192.168.100.1, 192.168.100.2 but i can ping 192.168.100.254 the SVI of switch. please also note i gave a command to swtich
after spending few hours. i issused a command on swtich ip routing on 3850 swtich and everything start working. could some one please explain what could be the casue of this issue. i could not understand this. why ip rouitng fix the issue. wasnt this network a layer 2 only.....
please do not forget to rate.
Julio E. Moisa
the IP routing command is used to enable the routing on the switch on a switch layer 3, by default it is disabled.
if you are going to use static or dynamic routing that command line must be enabled before.
based on your config, you are using static route to reach a destination, so ip routing command line must be enabled globally on the switch to allow the communication between the subnets of each devices. It will not affect your layer 2 capabilities.
Remember if the switch is working as layer 2 the subnets will not be able to communicate with others, a layer 3 device is required to complete that.
This link is related: http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst2960/software/release/12-2_58_se/configuration/guide/2960scg/swipstatrout.html
please rate the comment if it was useful.
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
Ganesh Hariharan
Agree with Julio, Ip routing feature is by default disabled and in order make the routing functionality working on device or inter vlan routing to ping different vlans via the same device.
IP routing command need to be enabled vlans which require communication can easily do via the centre device.
Hope it Helps..
-GI
