04-16-2015 08:10 AM - edited 03-07-2019 11:35 PM
We have installed several Catalyst 3850 48 port switches on campus. I have run into 3 incidences where a system connected to the port will not work (different buildings and different switches). A wire scope of the port reveled no problems, port security was off, and there were no log messages other than port up/down. I was not able to see a mac address of the system connected to the port. A different system exhibited the same behavior on the same port. Moved to a different port and all is well. This the 3rd (separate) switch that has done this. Has anyone else seem this?
Bob G
Solved! Go to Solution.
04-16-2015 08:40 AM
There is a bug CSCui93088 that describes this behavior, however it is with poe ports.
This fix is to do a
shut/no shut
or
plug a non poe device into the port, then plug the poe device back into the port and all is well.
Hope this helps...
If so, please rate.
Thanks.
04-16-2015 09:45 AM
Note the Feedback Forum is a "Please do not post content other than feedback regarding the Cisco Support Community experience within this community." kind of forum.
So I moved this thread to more appropriate one.
04-16-2015 08:40 AM
This fix is to do a
shut/no shut
or
Hope this helps...
If so, please rate.
Thanks.
04-16-2015 08:40 AM
Will give that a try...thanks
Bob
04-16-2015 08:41 AM
Your welcome.
04-16-2015 09:45 AM
04-16-2015 10:42 AM
Thanks for rating, but I wish you should select the Charles Hill's response as the correct one, not my moderator's notice ...
