3850 Power Supplies Interchangeable with 3750-X?
snikiforow
Power Supplies look the same, share the same electrical properties, fit the same - just a different model name.
Anyone have any information on this?
Other than saying 3850 supports same wattage power supplies as 3750-X, the Cisco documentation doesn't specify...
Mark Malone
yes you can use these makes no difference there just power supplies , they also fit 3650x series as well.
We have swapped them between multiple  platforms before with no issue
Mark Malone
Thanks - Cisco confirmed this as well!
Yes - I did verify the wattage/AMPs,  still wanted to verify. It's all same but did not find anything on Cisco site so raised the question. Thank you all for prompt reply...
Thank you! I will go ahead use it then...
