3850 Radius authentication with NPS
trylvis123
Hi everyone,
Working on setting up some new 3850 switches, and I have some problems getting aaa radius authentication up running.
I've used the same config as on some 2960X switches, but I get the "Access denied" error when I try to log on.
I use a Windows NPS server as radius, and wonder if there is any different settings for 3850, versus 2960X? I've set the radius attributes:
Vendor: Cisco
Value: shell:priv-lvl=15
Which work for the 2960X switches, but not 3850.
Config looks like this:
aaa new model
aaa group server radius TEST
server-private 192.168.1.1 key 0 mykeymykey
aaa authentication login default group TEST local
aaa autorization login default group TEST local
line vty 0 15
transport input ssh
Thanks in advance!
We have exact issue too.  2960x (24 & 48 port) work fine, but all 2960CX 8-port and our 3850 units do not work with same aaa config.  Is there hardware/boot rom/ or implementation differences for 3850 and 2960CX 8-port devices that would work so differently?
