3850 - SPAN port
crisponions
I recently swapped out a 3750 stack with a 3850 stack and I am not getting the same results when I am spanning a port.
I am mirroring the switchport connected to the inside of our ASA and sending the traffic to the switchport of my IDS.  I have noticed that the captures do not seem to contain traffic destined TO the internet (transmitted from the source port).  It contains TX traffic that is destined to the inside ASA interface but not traffic that should be flowing through the ASA.
I do see the return web traffic (RX).
My config is the same that I used on the 3750 so I am not sure what is going on.
3850-switch#sh monitor session 1
Session 1
Type                   : Local Session
Source Ports           :
    Both               : Gi1/0/10
Destination Ports      : Gi1/0/11
    Encapsulation      : Native
          Ingress      : Disabled
3850-switch#sh run int g1/0/10
Building configuration...
Current configuration : 63 bytes
interface GigabitEthernet1/0/10
switchport mode access
end
3850-switch#sh run | inc monitor
monitor session 1 source interface Gi1/0/10
monitor session 1 destination interface Gi1/0/11
0 Replies 0
