3850 stuck in booting up
Der
Hi everyone.
Is there anyone encountered this problem with a standalone switch?
it stuck on this
Booting...
Interface GE 0 Link down***ERROR: PHY link is down
The "IP_ADDR" environment variable is not set.
and it's not functioning.
I cannot also go to rommon mode and it has amber light indicator Syst Actv XPS S-Power.
Thanks in advance.
7 Replies 7
Mark Elsen
   - Study and review https://www.cisco.com/c/en/us/support/docs/switches/catalyst-3850-series-switches/117552-technote-cat3850-00.html
             Look for instance at the emergency install option , (with or without factory reset)
             Read the complete document too.
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Hi @Mark Elsen I have already access the switch by pressing the mode button in front for at least 10second and already did the USB recovery also the emergency recovery.
After I booted the flash bin it suddenly stuck and it will turn on the amber light indicator on Syst Actv XPS S-Power.
Do you think it's hardware issue?
  - Looks more and more like a hardware problem to me (indeed) ; you may also try a full power cycle with cold start and attach a console first. Look at the self test sequence for instance , watch for errors , if any ,
 M.
       Beauty and terror
      Just keep going
       No feeling is final
personally was unable to get to the switch prompt. Attempted to hold down mode during and after the power cycle but still ended up with SYST, ACTV, XPS, and S-PWR in amber and unresponsive screen on m1 mac. Also attempted to the TFTP server but never got to the switch to call for the upload. Wondering if this is a hardware issue on my end?
Der
I don't know what happened but this commands worked to me.
"SWITCH_IGNORE_STARTUP_CFG=1" followed by the command "boot".
Thanks for the helps. Appreciated!
[SOLVED]
  - Great to see that the device became alive , not sure if you can keep that setting for production and or after configuring and saving to startup configuration , you may need to set the value back to 0
 M.
       Beauty and terror
      Just keep going
       No feeling is final
Leo Laohoo
In ROMMON, post the complete output to the command "set".
If the switch is able to boot the OS, post the complete output to the command "sh romvar".
