3850X model confusion
ahmad82pkn
Level 3
Level 3
Hi, Can any one explain if below two models has builtin 1 G electrical Copper ports?  or only SFP Base modules supported, means it will have empty slots and additional copper or fiber sfp need to be bought?
actually i am looking for 3850x model with builtin copper and support of 8x10G module.
WS-C3850-12X48U-S
Stackable 12 100M/1G/2.5G/5G/10G and 36 1 G UPoE ports, 1 network module slot, 1100 W power supply
WS-C3850-24XU-E
Stackable 24 100M/1G/2.5G/5G/10G UPoE ports, 1 network module slot, 1100-W power supply
Hi.
I might be wrong, but I think it means the speed capability of the port.  Eg Capable of 100Mbps, 1Gbps, 2.5Gbps ...
5 Replies 5
Iulian Vaideanu
Level 4
Level 4
Yes, those are builtin copper ports (as far as I know there's no "PoE over copper SFP").
Also, -S and -E are available for both models, meaning IP Base or IP Services feature set (so there would be a total of four 3850 models with builtin copper ports and support for the 8x10G uplink module).
what does this portion means ? 12 100M/1G/2.5G/5G/10G
it also contain 1G
Hi.
Those are Multigigabit Ethernet ports - you can, of course, connect such a port to some 1G device and let it auto negotiate or manually set speed, as shown for example in slide 11 of this presentation:
http://www.slideshare.net/Cisco_Mobility/technical-overview-of-new-cisco-catalyst-multigigabit-switches
Wow that was a good read :)
