4 AP connect to Catalyst 2960
evgenychel
Hello.
Help me please.
I am have PoE switch Catalyst WC-2960CPD-8PT-L and 4 AP AIR-SAP2602E-E-K9.
I am want connect and power AP to Catalyst, but via PoE not swith on mor than 1 AP..
If connect second or more acess points PoE indicator flashes orange and AP not swith on..
What can be problem?..
Thank You.
7 Replies 7
Mark Malone
You need to supply some further info to troubleshoot here
Need to see the port configuration and also the show power output while both aps are connected
also supply show log and show int from both of the connected aps
These aps support 802.3af , the switch also supports that poe so it should work
Powering Options
802.3af Ethernet Switch
Cisco AP2600 Power Injectors (AIR-PWRINJ4=)
Cisco AP2600 Local Power Supply (AIR-PWR-B=)
Hello.
Thank You for fast answer.
AP swith on if connect to any PoE port Catalyst, not switch on any 2,3,4,5,6,7 and 8 AP.
A am can not go to web page Catalyst.. Standard password - cisco not work.
Screan shots is attached. I am can make screan shot for secont AP, but need disconnect first AP..
Need do?..
Thank You,
Kindly post the complete output to the command "sh power inline".
Hello.
Thank You.
I am purchase other commutator - WS-C2960C-8PC-L.
WC-2960CPD-8PT-L - can not power my 4 Aps..
Thank You.
it seems,that switch wouldn't have enough power to power up more than one 2602 by default.take a look here it says the available power 30.8W.
though,It is not quite clear on the guide whether that 30.8W is through the uplinks or when it is connected to the power adaptor.You could test this out since you have the switch anyway
You might be able to set absolute power on the port and limit the APs only to get required power(12.95W),they usually draw 15w.this way you'd be able to run 2 APs off the switch.
***Please rate all the useful posts***
-Prabath
Ashok09
Am also facing same problem, I have connected 2 AP's in the Switch C9200.
Whenever the Power Supply up and down. The Switch will be UP with UPS support. The AP1851 is up but the AP C9115 will restart automatically.
Any Suggestion please
SW03#sh power inline gi1/0/26
Interface Admin Oper Power Device Class Max
(Watts)
Gi1/0/26 auto on 24.1 C9115AXI-D 4 30.0
SW03#sh power inline gi1/0/40
(Watts)
Gi1/0/40 auto on 19.9 AIR-AP1852I-D-K9 4 30.0
SW03#
Module Available Used Remaining
(Watts) (Watts) (Watts)
1 740.0 48.0 692.0
jhoney12
Grateful for the valuable input from all the commenters.
