4331 IMIX throughput
Tomasz Bres
What is the IMIX throughput for Cisco 4331 with base performance license?
Mark Malone
They only released it for some ASRs not the ISRs for some reason , data sheet doesn't even mention it, maybe TAC could tell you
anyway this is the most detailed sheet I have saved that I could find that's publicly available if you come across something with ore information please post it
http://www.cisco.com/c/dam/en/us/products/collateral/routers/4000-series-integrated-services-routers-isr/enterprise-routing-portfolio-poster.pdf
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages wha2tsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
I think the 4K series limits throughput through the chassis to a specific bit rate.  So, regardless of whether traffic is all minimal size Ethernet, IMIX, or maximum size Ethernet, maximum bandwidth throughput will remain the same.  However, from reading benchmarks on the 4451, if you activate every possible feature, maximum licensed throughput isn't always maintained.
