4500 blade comparison
ciscors
Guys, I need to get a good blade with least oversubscription and am debating between WS-X4306-GB vs. WS-X4506-GB-T
I don't need the POE features or the copper capability out of the blade (just need GBIC connections)
Can someone tell me if the 4506 has better line rate or port buffers or anything performance-wise which leads over the 4306 module?
Thank you
Joseph W. Doherty
You wrote "need GBIC connections", but it appears the 4506 use SFP.
On the face of it, both card slook similar in performance, i.e. 6 gig ports at line rate, as found in: http://www.cisco.com/en/US/products/hw/switches/ps4324/products_data_sheet0900aecd802109ea.html
PS:
If the SFP isn't an issue, and since features/performance appears the same, you may want to price out both cards and connectors.
szahid
Level 3
Level 3
Performance wise , there is no difference between the line cards , except the fact that 4506 offers SFP/ Copper option. Both line cards provide 6 Gig non blocking performance. In 4500 , buffering happens at the supervisor level and not at the Line card level , so its same as well for both cards.
Salman.
