4500 Line Card Question
visitor68
Level 5
Level 5
Hi, which 10G linecards are available for a 4510 chassis with a SUP-6E?
I believe its only the WS-X4606-X2-E 4500E 6-Port 10 Gigabit Catalyst Switch Module.
Is that correct?
How much do they list for?
That is correct. There is one other module, but it is not supported on 4510.(WS-X4712-SFP+E )
Please check the link below for more information about supported modules.
http://www.cisco.com/c/en/us/products/collateral/interfaces-modules/catalyst-4500-series-line-cards/product_data_sheet0900aecd802109ea.html
Also check these links.
http://ciscoprice.com/gpl/WS-X4606-X2-E
http://www.amazon.com/Cisco-WS-X4606-X2-E-6-Port-Gigabit-Catalyst/dp/B0012CKVCM
Hope it helps,
Masoud
Hope it helps,
Masoud
