12-11-2016 09:58 PM - edited 03-08-2019 08:31 AM
In 4500 series which support vss and what is the license required ?
The switch should support fiber connectivity and copper connectivity
Please suggest
12-12-2016 07:33 AM
But It has only SFP+ ?
12-12-2016 08:00 AM
Correct, but SFP+ supports gig or 10g, and they might support copper SFPs too. If the latter, it would also support you OP device requirements.
12-12-2016 08:13 AM
You can tell me the sfp(rj45) part number ?
12-12-2016 09:52 AM
GLC-T
NB: According to release notes, it won't auto-negotiate 10/100/1000 speed, but you should be able to manually run at any of the three speeds.
