4500X Jumbo Frame, reload?
waqas gondal
I have 2 4500X switches in VSS mode and I need to increase the mtu to the maximum.
Will this require a reboot of the switches? If so could I do one switch at a time?
Reza Sharifi
You would have to do it per interface and reboot should not be required. Max size is 9170 per interface.
Reza Sharifi
Hi, can I ask if you can do this only for a VLAN and not on a specific interface?
