4500x VSS Netflow problem
Denis Orlov
Hi. We faced with this problem too.
What we have at this time:
1) Two 4500x in VSS.
SW-C4500X-CORE#sh switch virtual
Executing the command on VSS member switch role = VSS Active, id = 1
Switch mode                  : Virtual Switch
Virtual switch domain number : 20
Local switch number          : 1
Local switch operational role: Virtual Switch Active
Peer switch number           : 2
Peer switch operational role : Virtual Switch Standby
Executing the command on VSS member switch role = VSS Standby, id = 2
Local switch number          : 2
Local switch operational role: Virtual Switch Standby
Peer switch number           : 1
Peer switch operational role : Virtual Switch Active
SW-C4500X-CORE#
SW-C4500X-CORE#sh switch virtual role
RRP information for Instance 1
Valid  Flags   Peer      Preferred  Reserved
               Count     Peer       Peer
TRUE    V        1           1          1
Switch  Switch Status  Preempt       Priority  Role     Local   Remote
        Number         Oper(Conf)    Oper(Conf)         SID     SID
LOCAL   1      UP      FALSE(N )     110(110)  ACTIVE   0       0
REMOTE  2      UP      FALSE(N )     100(100)  STANDBY  2456    7573
Peer 0 represents the local switch
Flags : V - Valid
In dual-active recovery mode: No
RRP information for Instance 2
               Count     Peer       Peer
TRUE    V        1           1          1
LOCAL   2      UP      FALSE(N )     100(100)  STANDBY  0       0
REMOTE  1      UP      FALSE(N )     110(110)  ACTIVE   7573    2456
Flags : V - Valid
SW-C4500X-CORE#
SW-C4500X-CORE#sh switch virtual redundancy
                  My Switch Id = 1
                Peer Switch Id = 2
        Last switchover reason = none
    Configured Redundancy Mode = Stateful Switchover
     Operating Redundancy Mode = Stateful Switchover
Switch 1 Slot 1 Processor Information :
        Current Software state = ACTIVE
                 Image Version = Cisco IOS Software, Catalyst 4500 L3 Switch  Software (cat4500e-UNIVERSALK9-M), Version 15.2(5)E, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2016 by Cisco Systems, Inc.
Compiled Tue 19-Jul-16 15:19 by prod_rel_team
                          BOOT = bootflash:cat4500e-universalk9.SPA.03.09.00.E.152-5.E.bin,1;
        Configuration register = 0x2102
                  Fabric State = ACTIVE
           Control Plane State = ACTIVE
Switch 2 Slot 1 Processor Information :
        Current Software state = STANDBY HOT (switchover target)
           Control Plane State = STANDBY
show virtual switch redundancy is not supported on the standby
SW-C4500X-CORE#
2) We trying to get net-flow data about traffic using Flexible NetFlow.
Our FNF config looks like this
flow record r1
 match ipv4 protocol
 match ipv4 source address
 match ipv4 destination address
 match transport source-port
 match transport destination-port
 collect interface input
 collect interface output
 collect counter bytes
 collect counter packets
flow exporter nfcoll
 destination 192.168.6.52
 transport udp 9996
flow monitor m1
 exporter nfcoll
 cache timeout active 60
 record r1
interface TenGigabitEthernet2/2/1
 no switchport
 ip flow monitor m1 input
 ip address 10.255.3.2 255.255.255.252
3) After that we prepare our netflow collector for recieving netflow data.
As a result we realized, that netflow data from interface Te2/2/1 is not exported.
And soon we realize that no flow data collected on interface, that belong to stanntdby switch.
Netwflow data collected on active switch interfcaces only.
More over when we try to view local netflow cache on active switch via CLI - we see nothing.
4) Also we try to view netflow status on standby box.
SW-C4500X-CORE#remote login module 11
Connecting to standby virtual console
Type "exit" or "quit" to end this session
SW-C4500X-CORE-standby-console#sh flow interface
So, as you can see: netflow monitor is not applied on our interface.
Now we trying to understand: is this a BUG or may be we incorrect configure netflow.
Please, somebody clarify this situation.
0 Replies 0
